Haus 1010 light flashes 7 times
Was spining at varying speeds on previous wash, last wash the machine filled as normal, but threw light code of 7 flashes with door locked. left overnight the door unlocked to enable clothes to be removed, re plugged machine in, switched on and it emptied as normal, then 7 flashes of light, nothing after.
SOURCE: door not unlocking
hi i have a problem with Lavamat Lavalogic 1600 Front Load Washer error cade cf 429467295
Posted on Mar 18, 2008
SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Posted on Aug 23, 2008
Krazytech
  • 725 Answers
SOURCE: Not only is my asko washing machine leaking, the
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
SOURCE: Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Posted on Jul 20, 2010
Macmarkus
  • 2605 Answers
SOURCE: Kenmore elite HE3 washing machine
Welcome to FixYa.
Based on your description..."fills with water while the door is open (or closed) and the machine is not on
" You likely have a faulty inlet water valve.
Here`s an easy way to check...
1) First drain the standing water which presently exists, if any.
2) Unplug the washer from the wall/power outlet and allow a period of time to pass, 12 hrs or so. If the unit has standing water in it after wards you need a valve.
If it doesn't have water in it after-wards then the valve is being energized when it is plugged in even when it should not...that indicates a faulty control unfortunately, but not very likely.
The valve # is 8182862 and varies in pricing around $40 - $75.
It should be available at most brick and mortar appliance part locations or if you prefer on-line shopping try "searspartsdirect.com" "repairclinic.com" or "appliancepartspros.com" to name a few.
To swap out the valve simply follow these steps...
**Unplug the unit from the wall before attempting any repairs suggested here...safety first**
1) turn off the water and unfasten the hot & cold fill hoses going to the washer.
2) remove the three screws along the back of the top panel and then slide the top panel back slightly and pull up. The panel should lift away.
3) in the left rear corner ( when observing from the front of the washer )you should now see the valve.
4) remove the wires, carefully the harness has little release tabs which must be bent back slightly to pull the wire & harness off.
5) remove the hose to the dispenser assembly, a pair of pliers or vise-grips works well here.
6) remove the screw on the outside back wall of the washer and pull the valve out, voila !
465fa60.jpg Reverse order to put the new one in and good job. You potentially saved yourself $200 or more for parts and labour.
Hope this answers your question but more importantly solves your problem.
Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
Testimonial: "Thank you kindly, Macmarkus. Pictures and everything!!! We'll follow your suggested procedure."
WTW4850XQ spins for a few seconds, then quits
Place the unit in diagnostic to do this make sure machine is off turn control knob to the left at least 3 times to clear now turn knob 3 clicks to the right 1 left 1 right all lights should light up do this within 6 seconds if you don't get lights repeat process I do this everyday so be patience once all lights are lit turn to the right until done light is lit press start button you will now see lights flash in varying sequence the way to read this the lit fill/sense light is the f code, wash light =8, rinse =4, spin=2, done=l when fill/sense light is not lit this is the second halve of the code example F7E1 you would have fill/sense lit, rinse=4, spin=2,done=1 F7 code, non lit fill/sense done=1 okay you may have more than 1 code it will continue to read the same code until you turn the knob once to the right the control will hold up to 4 codes at a time once you find the codes we'll go from there
Feb 04, 2014 | Whirlpool Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I need a user manual for a HAus HW50-1010 Washing machine
http://www.manualowl.com/m/Haier/HW50-1010/Manual/180896
It seems that Argos recycled a brand called Haier (Chinese) and turned it into HAUS (German)!!
The washers are exactly the same. Manual is the same.
Jul 13, 2010 | Washing Machines
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
