Question about Whirlpool LSQ9610L Top Load Washer
Washer sometimes will not spin dry.
Machine agitates but sometimes will not spin dry. Other times it works normally.
  • 1 more comment
  • boyd_cox Jan 12, 2009
    Thanks. I will just have to replace the clutch assy. I will replace the coupler while I am in there.
  • boyd_cox Jan 14, 2009
    OK, How do I get the agitator out? I removed the cap and found the bolt, but it just turns and will not come out.
    Thanks. Got it out. Now I am having trouble getting the clutch retainer ring in.
  • 242 Answers
Hello , this is the first sign of your clutch going out , it is not engaging on the last spin cycle soon it will almost never spin. the clutch is tough to get to and is not much money. you would have to be willing to pull the gear case to replace the clutch. a repair company would charge around 150.00-200.00 dollars total. Here is a different look at your problem follow the link I added , it is part # 5 as a kit.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0307038-00004.png
Please ask any questions you may have.
Phil
Posted on Jan 12, 2009
  • 1 more comment
  • Phil Brantley
    Phil Brantley Jan 12, 2009
    That would be a good idea , they have an updated coupler with a metal inside that are good to use for a few dollars more. good luck.
    Phil
  • Phil Brantley
    Phil Brantley Jan 14, 2009
    If there is a spring under it it will feel like its just spinning but it is coming out just keep loosening it until the bolt comes out , then you should be able to grab the bottom of the agitator and pull up with only removing the bolt dont take the agitator apart.
  • Phil Brantley
    is that the ring with the hook at the end?
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Feb 01, 2009 | GE Profile WPRE6100G Top Load Washer
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Stacked Matag washer & Dryer (Dryer on top)
Opening door while spining should stop the machine. Since no water comes in, the agitate stage will not work even when the timer will be on this spot. Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck !
Sep 11, 2007 | Washing Machines
Whirlpool LSQ9610L Top Load Washer Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
