Question about Water Heaters
No hot water - have replaced both element and thermostat
I have replaced both the thermostat and element but my hot water still does not heat up
  • Water Heaters Master
  • 5,089 Answers
  • 3 Answers
SOURCE: no hot water
If the water does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Take care here - a defective circuit breaker can give a false 240 volt reading - check for the 240 volts across the upper element (i.e. when the 240 volts has a live load on it, not just an open circuit test).
Also, remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Posted on Nov 17, 2008
freetek
  • 5568 Answers
SOURCE: limited hot water
Some checks are surely possible but PLEASE make sure that the 220VAC is absolutely shut down.
In a home we built in 1977, circuit breakers were improperly marked and I, with decades of experience, believed I had turned off the power to our water heater only to find that it was still 'hot' and blew away a screwdriver tip before thinking to check across terminals to see if the voltage was in fact OFF.
You may have the same problem I had twice over ~30 years; that the lower heating element is open/failed. These typically will gather a coating of mineral deposits and eventually be unable to transfer their heat to water fast enough to avoid overheating and failing.
The limited hot water comes from the fact that the thermostat is checking for temperature at the exit point of the heater; the top. The thermostat turns on both elements but with only the top one still working it heats 10-15% of the tank capacity and then shuts off.
With your meter set to the lowest Ohms scale (typically 200 Ohms), measure across the element terminals. You should measure pretty much a short since the elements have an extremely low resistance; on the order of 10-20 ohms, if you measure anything that goes 'off-scale' on the 200 ohm range (normally blinking), the element is shot.
Don't forget to drain the tank before pulling out the element!
If you are in the US, near any city, check your white pages for: Johnstone Supply or check their website to see if one is near you.You will pay 1/3-1/2 hardware store prices for the replacement element - buy two, store the second one. They are 'wholesale' to the trade but have never been refused.
If you don't feel like wading through their extensive website, you can take the element with you and they can give you what you need.
Posted on Jan 25, 2009
  • 408 Answers
SOURCE: Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Posted on Mar 07, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
  • 193 Answers
SOURCE: Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Posted on Apr 21, 2010
Testimonial: "It is very good advice. I bought a tester to check out both upper and lowre thermostat and heating element; I've replaced the lower heating element "
Heater element only gets 120volts. Should be 240v, correct? Water does not heat up.
Testing voltage on heater can be tricky since elements can test 120Volt to ground all all times.
This is because thermostats only turn off 1 Hot leg in the 240Volt circuit, while the other hot leg remains live. Each hot leg in 240Volt circuit is 120Volt.
http://waterheatertimer.org/B220C.html#120-240
Troubleshoot electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Try following things in order: Press reset button. Test elements. Replace thermostats.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add comment.
Apr 29, 2013 | Water Heaters
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I just installed a marathon 50 gallon 4500 watt, hot water heater. I do not have hot water. The wiring to the upper element and thermostat all test at 240 volts. The lower element and thermostat show no...
The top element should be heating if there is 240 volts across the element terminals. I take it that the top element is the booster element. The thermostat for the top element is normally a 2 pole thermostat which switches the neutral to the bottom thermostat once it reaches temperature. Once this occurs then the bottom element will start to heat. The top element will only come on when you use all the hot water. Is this supply on the off-peak rate? When testing always check the voltage across the element terminals.
Mar 20, 2011 | Rheem Water Heaters
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 03, 2011 | Reliance & Lowboy& Electric Water Heater
I have a reliance 606 electric water heater. This is my problem. The water gets unbearably hot then I have to reset the reset button on the water heater. I am thinking that I need to replace the heating...
you need to replace the thermostats. the elements are working, as your water is getting hot.
I would replace both upper and lower thermostats. be sure to set the temps the same for both.
the thermostats sit against the tank and read the tank temperature. if one is malfunctioning, they will over heat the water, causing you to get severe hot water.
also as a precaution, I would replace the temperature and pressure relief valve. if your water is getting that hot, and this has not "popped" then it is time to replace it.
Sep 06, 2010 | RELIANCE ELECTRIC WATER HEATER
The water gets too hot and trips the reset on the thermostat.
Two possibilities. 1 failed upper or lower Tstat 2 Shorted element
To test element: disconnect both wires to element terminals. use continuity tester to see if there is continuity through element (one probe on each element terminal) If no continuity element is bad. Then test for continuity between each element terminal and the water heater itself.( one probe on element terminal and one probe grounded on bare metal or inner tank.) If there is continuity from terminal to ground, element is bad and also can cause tank to continue heating even when thermostat shuts off. This is because the thermostat only shuts off one pole of the 220 and a shorted element can continue heating from the 2nd pole.
If both elements test OK and water heater heats the full tank( tank feels hot at bottom element access panel when no hot water for 2 hours) most likely the lower thermostat is bad.
Jan 25, 2010 | Reliance Water Heater #6-30-DORT 30GAL...
Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
Jan 18, 2010 | RELIANCE ELECTRIC WATER HEATER
No hot water
Nov 15, 2008 | Water Heaters
Water Heaters Logo
21 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
