Question about Lexmark P4350 All-In-One InkJet Printer
Sd card in adapter from cell phone will not work
Once I insert the sd card (inside the adapter) it trys reading it then it will tell me Memory Card Problem
Does this printer not support these kinds of cards?
    Genius:
  • 1,269 Answers
The card is not supported if the printer is not reading it.
Posted on Jan 12, 2009
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
Nov 07, 2011 | LG GD510 Cell Phone
Sir i forgot my micro sd (memory card ) password...pl tell me how to unlock dat password
Unfortunately if you do not have the password to your micro-sd card it can't easily be unlocked. The card has built in protection for this reason.
Mar 02, 2011 | Cell Phones
How do i get my 2gb memory card to work on my samsung e900
Hi - Sometimes devices are finicky about which SD cards they work with. I suggest you try a different brand card. Be sure to purchase it where they have an easy return policy just in case. The phone definitely supports two GB cards.
Luckily two GB cards are pretty cheap and it's always good to have a spare.
Good Luck, Mikeywaf
Mar 01, 2011 | Samsung SGH-E900 Cellular Phone
My nokia e65 memory reads "no memory inserted", but i have a 2gb sd micro which was inserted by the manufacturers. However the memory chip is accessible on the computer . Kindly sort me out
Remove the memory card and check using a memory card adapter on the card reader of the laptop. If the memory works fine with a scan and shows up well on the properties the capacity of the memory.Then replace the card back into the phone using the correct direction. Some times the direction is deceiving and so it might not read. Once in position if the card is not detected, then either the slot has a fault or the motherboard interface is defective.
Sep 18, 2010 | Nokia e65 Cellular Phone
Continues to tell me to insert it when it's there
The reason the phone is not reading the memory card is either the phones memory card slot is faulty or the memory card is not in good conditions.
To test if it is the phone, try a well tested memory card in the phone to see if it reads it, if it does not then it is the memory card slot.
to solve that, try to open the phone and clean with spirit and drey it with the heat from a bulb, or you can replace the slot.
To test if it is the memory card, try the memory card another phone that the memory card is working fine.
if it does not read the memory card, then the fault is from the memory card, and the solution is simply to replace the memory card.
Make sure the memory card is not above 16GB.
Take care
Jun 14, 2010 | Samsung SCH-U450 Cell Phone
I can't find my install cd and I can't get pics off of my old phone onto my computer, help! These are valuable since I took pictures of President Barack Obama when he was campaigning in Texas. I really...
hi,
does your phone have a memory card?
if yes, do these..
>>if the pictures is stored in your phone memory, then copy the pictures from your phone memory to your memory card. once copied, switch off your phone, remove your memory card, get your memory card adapter, insert memory card and insert it to your laptop sd reader slot and copy the files from your memory card to your laptop. if you use desktop and has no sd memory card reader slot, borrow memory card reader from a friend, connect it your computer, insert the your memory card from there and once read, copy the files to your computer. this also is applicable if you want to copy files from your computer to your phone.
>>if it doesn't have, then, borrow a bluetooth dongle from a friend, pair it with your phone, and send the file from your phone, one after the other...
good luck..
Feb 21, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Memory card micro sd cannot format
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Mar 11, 2009 | Samsung Eternity Cell Phone
    Computer is not reading my Micro SD, but phone is reading..
    What size is the SD card in GBs? If it is larger than 2GB (4 or 8) do you have a SDHC card reader?
    Also try formating the card first in the phone and then using it. Using it straight out of the package, while able to be written, my have difficultly with other devices reading the data.
    Jul 23, 2008 | PNY 2GB microSD Memory Card
    Micro SD 2 GB just stopped working
    The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
    Jul 02, 2008 | SanDisk 2GB microSD Memory Card
    Lexmark P4350 All-In-One InkJet Printer Logo
    75 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
