Question about Electrolux Insight EKC6049X Stainless Steel Range
(electrolux insight cooker) I have smashed the outer glass of the bottom oven, Can I get a replacement piece of glass rather than a whole door unit?
5 Suggested Answers
SOURCE: The glass has shattered in my electrolux eou6330x door
It will be difficult to find just the glass, have it shipped and fumble with getting it into those factory sealed doors. The entire door can be purchased for right about $50. Click here to see. There is not a picture associated with this item, but it is the correct part number.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Feb 22, 2010
Testimonial: "thanks"
  • 40 Answers
SOURCE: need a manual for electrolux insight cooker
try the electrolux website. www,electrolux.com
Posted on Apr 07, 2010
SOURCE: electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Posted on Dec 30, 2010
richroth
  • 9472 Answers
SOURCE: The inner glass of the
Here is a link to the part you requested.
Posted on Aug 20, 2011
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Broken outer glass
Please can you help to find a part number for outer door
glass or is any other outer door glass suitable for
AEG MCC3880EM I can fit in? Many thanks
glass , how much it would cost or is any other outer door glass suitable for
Dec 07, 2012 | AEG Ovens
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
How can you take the inner glass out of the cooker door to clean the inside?
Lets see if we can help.If you open door slightly and look on the top of the door edge,you will see a metal plate going across the full width of the door.If you gently push this towards the inside of the cooker,pushing from each outer edge,it is held in with 2 spring clips.When you have this clip off the glass will just slide up and out for cleaning.The glass will normally be marked for correct replacement, (eg.To Inside and or top).Be very careful when lifting out glass and also look out for little rubber buffers that protect the glass when it is refitted.
Hope this helps.
Jun 25, 2010 | Electrolux Insight EKC6049X Stainless...
Hi. The outer glass grill door has come away and smashed on the floor when going to open grill by the handle. Can't see that there were any screws in the bottom of this. Would they have been factory...
Sometimes the glass is bonded to the door (glued) which may be why you can't see any screws.
It seems as if you are going to need a new grill door complete.
Dec 30, 2009 | Electrolux EOG9330 Gas Double Oven
Door glass shattered 3 hours after cooking
Hi there folks It also happened to me, so after ringing rangemaster they said it can happen due to faults in the glass, unfortunately my warranity had run out and they wanted t charge a fortune to repair. so i had a look inside the door my self which is only four screws on the sides to remove the outer skin to find it was a single piece of ordinary toughend glass about 300mm x 300mm fixed in place with six clips like the ones you find one those glass picture frames, i got a new piece from me local glass merchants for less than £10 and it took only mins to fix job done, I hope this help someone and it my save you quite a bit of cash Cheers folks Markbricky
May 31, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Broken outer panel of glass on cooker door
I found a replacement for my oven on ebay. Be careful, though, because one seller offered one that was the wrong size.
Apr 01, 2009 | Ovens
Electrolux Insight EKC6049X  Stainless Steel Range Logo
79 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
