Question about Hoover AAA140 Front Load Washer
WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
Hoover 140 aaa washing machine starts off cycle by filling with water for about 20 seconds then everything stops and it shows up error 5. i don,t have my manual so have no idea what error 5 is. please help.
  • Anonymous Mar 30, 2014
    when machine starts it goes for 20 seconds then stops and beeps
    once ive turned on machine it starts for about 20 seconds then stops and beeps no water
The carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Posted on Jul 16, 2007
    Problem Solver:
  • 16 Answers
The usual issues with this type of washer is the relay board located inside the top of the unit. as i remember mfgs make a nice unit but are not so good for sealing the electronics off from the rest of the unit. chances are some moisture is up in the relay or relay socket. easy access you will see several relays. pull and tag each as you do to avoid confusion. check for corrision build up on any part of this unit. this should help.. gl k
Posted on Jun 11, 2007
My hoover 500mb 5.0kg washing machine fills up fine at start of cycle then just washes for a bit then just stats to fill up and wont stop till I stop it
I had a similar problem and not sure whether my solution would help you.It was to do with the position of the waste pipe.It should raised about 2ft. ,looped before discharged into the washing machine tee.when the discharge hose is lying on the floor there's a possibility that the water is filling up and going straight out.By raising it you are letting it fill up and presumably triggering the water level sensor.Hope this helps.
May 29, 2017 | Hoover Washing Machines
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Feb 17, 2016 | Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
Hoover AAA140 Front Load Washer Logo
319 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
