Question about DeLonghi ESAM3500 Espresso Machine & Coffee Maker
Fill tank When I fill the tank with water the machine tells me to fill tank even though it is full. The machine will not work
  • markponymoor Dec 08, 2012
    The float in the water tank moves freely so it is not that, that is the problem
Delonghi problems
turn off the machine and after 2 minutes turn it back on
Sep 01, 2014 | DeLonghi Prima Donna Avante ESAM6700...
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
Gaggia Titanium SUP027 YDR Syptom: Displays Fill water tank even though the water tank is full and freezes the operation of the coffee machine
Be sure to check the float in your water tank. It looks like this: http://www.cerinicoffee.com/item.asp?PID=1318
If the float is not floating then you need to replace it.
Jun 05, 2011 | Gaggia Titanium Espresso Machine
Fill water tank message will not go off screen even though tank is full
Your magnet might have come out the the tank. You might have to get a new tank.
Sep 08, 2010 | Starbucks Saeco Italia Digital Barista...
I just purchased a used Royal Professional. The screen keeps telling me to fill the water tank even though it has water in it. Is there a way to get beyond the message? I can't get it to do anything and...
Hi
Do you have a gray cylinder in the water tank? If you don't that is you problem. That will float when there is water in the tank and tell the machine to work. If its missing or at the bottom, the machine won't work.
Mar 12, 2010 | Saeco Royal Cappuccino Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Getting ''Fill Water'' message even though Tank is full
Gently remove tank the slide it back in place make sure the back of tank makes good contact with the machine when it is being lowered so that the reed switch can read the magnet in the tank.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
"Fill water tank" prompt
this has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
DeLonghi ESAM3500 Espresso Machine & Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
