Question about Acer Iconia Tab A50010S16u Notebook
Acer iconia is turning off when unplugged on full battery
So when tablet is charging while powered on it works just find, the problem is when I unplugged AC adapter from my tablet, the tablet shuts down or immediately goes into sleep mode and does not recover right away when trying to wake tablet up.
  • norman Dec 08, 2012
    I did all the updates prepost and as mentioned in the original post, battery was fully charged when cord get unplugged. the tablet goes in sleep mode and will not come out of sleep mode until cord is plugged back in to ac power. at this point the tablet comes on by depressing of the power switch and then shuts down completely and i would have to restart tablet.
    Guru:
  • 571 Answers
There are two possible problems:
1. Software (Video Driver)
2. Battery
With regards to the software issue, you just need to update the video firmware or driver. Chances are, your acer is programmed to power savings mode when it's removed from the plug and when it changes the setting to power saving mode, the driver cannot support it because it's outdated that's why it goes off.
2nd Possible reason is your battery going dead. If that's the case, then you need to replace the battery.
I hope this helps.
Carlo
Posted on Dec 08, 2012
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
  • 2427 Answers
SOURCE: Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
Posted on Mar 01, 2010
SOURCE: Acer aspire one, won't wake up from sleep mode, screen blank
I'm having the same problem, but I don't want to have to turn off my computer EVERY time it does this. (I have not been able to shut down the laptop normally because it goes into sleep every time.) I've heard that after 3 hours it builds up an eletrical charge and you have to take the battery out, but I havn't had it on for 3 hours at a time.
Posted on Mar 16, 2010
  • 184 Answers
SOURCE: My Acer aspire 4935 is
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Posted on Feb 10, 2011
What would be a reason for my ACER Iconia A1-810 tablet not powering on with a full charge?
If it doesn't turn on with a charged battery, you may have a broken logic board. If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Acer tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Acer Tablet Repair Services.
Nov 12, 2014 | Tablets & eReaders
Tablet wont charge
Unfortunately Acer tables use a 12volt voltage. On eBay you can find replacement But make sure that the charging port is working.
Aug 21, 2014 | Acer Iconia A50010S16u Tablet Computer
Acer Iconia W3-810 2GB 32GB
It is possible that the battery is faulty and will need to be replaced, there are units that will not power on even on the PSU if the battery is dead, contact Acer support for help.
Jun 27, 2014 | Acer Iconia Tab A50110S16u 101Inch HD...
Inconia b1 tablet is new and won't charge past 16%
Make sure the power supply has power or that it is plugged in properly
Dec 27, 2013 | Acer Iconia 8gb 7-inch Tablet |...
My tablet iconia wont start
There should be a tiny reset button or pinhole (use a straightened out paper clip). If reset button/hole itself does not work, try pressing it while holding down the power button at same time. Otherwise, it sounds like you have a battery/charging issue (try another charger cord if available).
Dec 02, 2013 | Acer Tablets & eReaders
Iconia w5 wont turn on battery wont charge
Try to connect charger and power on tablet by pressing power button during 5/10 seconds.
If that doesn't work, since it's a new device, I would recommend you use the service of ACER.
Apr 01, 2013 | Computers & Internet
The battery in my Acer iconia 110 tablet stopped charging, I just bought it last week?
It is the problem of battery may be repaired.Please replace it with warranty.
Jan 22, 2013 | Computers & Internet
Tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Jan 02, 2013 | Acer Iconia Tab A200 Series Tablet with...
Acer Iconia Tab A50010S16u Notebook Logo
941 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
