Question about Ruud Heating & Cooling
Air flow works gas heater will not come on after replaced filters
What is the procedure having the heatert kick on?
    Genius:
  • 2,920 Answers
Put the thermostat on heat and set it at about 65 degrees or so and it should do the rest
Posted on Jan 12, 2009
MasterTemp 400K BTU heater kicks on for 20sec. and starts shaking, then turns off and repeat itself. Everytime it kicks on we smell gas as well. Water flow seems to be OK in spa and pool.
Even though you are smelling gas it could mean the gas flow is not strong enough.
When you say the water flow seems good, have you cleaned your filter recently?
If you are somewhat handy you can troubleshoot this heater by taking off the front panel turning it on and looking up to the back of the circuit board.
When it shuts off it will have red lights next to abbreviated words such as hl1 hl2.
Whichever light or lights are red will point you in the right direction of the cause.
Mar 27, 2017 | Pool & Spa
Display says "CFH" but heatert wont fire up. Just makes a clicking sound
You don't have gas supplied to the heater. It sounds like you have a gas powered unit and the clicking you're hearing is the sparker sparking.
Jun 07, 2015 | Pool & Spa
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
My furnace kicks on, runs a little while, kicks off, then kicks on again until desired temperature is reached
it could be the thermostat on the wall not working or the fan control is not working as it should also check to see if air filter is blocked
Oct 24, 2010 | Dayton Gas Furnace Heater
The heater is only kicking on low as the wate demand goes up the temperature of the water drops because the heater is not kicking up like it used to. The heater is a little over a year old.
See image larger
-Tankless water heaters are susceptible to lime build-up if not de-limed each year.
-Hard water will clog pressure-sensor and cause failure within 2 years if filter and softener are not working.
-Water flow and water pressure sensors inside tankless are succeptible to hard water deposits.
-Low water pressure from clogged pipes to municipal water problems to water well pressure valve can affect tankless burner
-Low-flow shower heads may not engage burner.
-With tankless-gas water heaters, sensors inside combustion area detect when incoming air flow is not adequate ... inspect inflow
-Your manual probably has a troubleshoot section.
-The manufacturer will refer you to installer.
-If you self-installed unit, that will void warranty to my understanding.
-There are water heater forums 1 2 3 4
-There are plumbers who will each have a different opinion
-There are Fixya experts who get paid to tell you the above.
-And there are local plumbers who are authorized dealers of the brand of tankless who get paid to fix them
Oct 07, 2010 | Rheem Tankless Hot Water Heater...
DESA Propane Heater Valve Apart
Do,not override the safety features on any units unless youre qualified. These are not overides ,but safety switches to tell when something is not right! Anyway, its time for a fall service overhaul or kit ---plug---fuel filter---2 air filters --clean the flame sensor---and vanes in the pump replaced.You can buy the kit and parts that you need a your local lawnmower repair shop or have them to order them!
Dec 14, 2009 | Desa International Propane Portable...
Larrs lite low knox ten years old fires for seven seconds.three times than goes into ignition lockdown.new fire sensor installed didn't solve the problem. gas flow adequate, could it be bad gas valve? ...
Are you sure that the flame sensor is installed correctly? If the flame comes on and the flame sensor is right in the flame, then the control module is not working right. It's not 'seeing' the flame sensor input. You can prove it by jumper across the contact wires on the flame sensor. If it stays lit when you jump out the sensor, it's not working. The flame sensor tip needs to be right in the pilot flame to sense heat.
Aug 29, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
27 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
