Question about Canon Office Equipment & Supplies
Paper doesn't feed
Machine makes a grinding sound when attempting to print. Paper starts to feed; however, jam signal comes on and machine shuts down. Paper never gets more than half way through.
  • blanchardw Jan 12, 2009
    Canon PC745
    It says paper jam and turns off. The grinding noise comes on when the copy button is pushed.
  • jpd8 May 11, 2010
    ? - You said the machine shuts down -- does that mean turns off or just stops and says paper jam? What is the make and model?
    Problem Solver:
  • 15 Answers
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Posted on Jan 12, 2009
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper jam, so small, can't even see paper
first off, unless you know that the paper is there, it's a possibility your machine is just saying or acting as if there is a jam when actually there is something giving a false reading or a failed part rendering it unable to print. Otherwise, if you happen to know where there paper is jammed at, attempt forcing a heavier stock paper through. say the jam is between two rollers attempt pushing a cardstock or index card thickness of stock through the rollers to attempt pushing the paper backward which might either remove the jam and make it removeable elsewhere, or make it so the machine can try to feed the paper through again this time allowing you to reach it.
Oct 28, 2008 | HP Computers & Internet
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Won't print
Sounds like a piece of paper is stuck inside the machine. Open all access doors and check. Remove the printer cartridge and reinsert. Make sure the print job has been purged from the queue.
May 31, 2008 | Lexmark X73 All-In-One InkJet Printer
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
235 people viewed this question
old marine
old marine
