CD drawer will not open
Radio works but CD drawer will not open to play CDs
    Habit-Forming:
  • 30 Answers
You have a load / eject motor issue.
That being said there should be a pinhole to eject the CD. Straighten out a paper clip and insert into the hole and press the manual eject button
Posted on May 07, 2016
  • Audio Player... Master
  • 1,258 Answers
This is most commonly a belt in the drawer mechanism and is easy to fix IF you have the right belt in hand and can access where it goes.
A technician will be able to help.
Posted on Dec 11, 2012
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
  • 31 Answers
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Posted on Sep 17, 2008
SOURCE: cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
Posted on May 18, 2009
SOURCE: NAD C521 CD Player
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Posted on Nov 08, 2009
SOURCE: The drawers on the left side that hold 5 cds will
I have the same problem and have just lived with the B deck for over a year. Just now with nothing to lose, I decided to open it up. I don't have a clue about the inner workings, but was on a mission to at least rescue the 3 discs that were held prisoner. I'm happy to say that not only did I rescue my discs, but I'm listening to a disc in tray 2 right now. All the trays now work. I don't know if my disc was jammed in the player or what the problem was, but it seems the act of removing the disc from the deck made all the difference. If you want to try this, take the 6 black screws out (top 2 on rear panel, 2 on left and 2 on right panel) lift the panel straight up to remove it. you'll see the white framework that houses the trays and the play deck near the rear. In retrospect I should have opened up the play deck first since that may have been the source of the problem. I suggest you try that. There are two tiny screws on each side of the framework. Not sure if you need to remove the two screws with the washer heads. I think they just hold the disc clamp head in place. Again, I'm trying to save you unnecessary work, but remove them if it still doesn't come off. Once you get the top of the deck off, you should be able to access your disc. Take it out, then plug in the player to see if the deck starts to operate. I was very surprised. The belts started spinning and I was hearing the startup sounds I hadn't heard in over a year. Hope this helps
Posted on Apr 03, 2010
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
A CD is stuck, it won't play, and it won't eject.
i would go to the website of the make of the 5 disk changer and click on the support page. there you should find answers to your problem
Mar 24, 2009 | RCA Audio Players & Recorders
I was putting CDs in my Philips 3-CD Player and
The best solution is to open the case and manually remove/realign the jammed cd.
Mar 13, 2009 | Philips Audio Players & Recorders
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
CD player does not work
10/6/08 Update.
Solved the problem myself.
Repositioned the printed circuit board with the CD Drawer open/close limit switch.
I suspect that the board shifted during shipping and failed to trigger the closed drawer position.
Player is now working.
Sep 27, 2008 | Emerson NR303TT CD Shelf System
Philips Magnavox Mini Hi Fi System
My FW14 MX 3701 CD Mini Hi Fi System will not play The CD stored in it.  The screen says DEF. Thanks.
May 16, 2008 | Audio Players & Recorders
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
179 people viewed this question
 Grubhead
Grubhead
