Question about Sony PlayStation 3 (320 GB) Console
What's your problem?I changed the PS3 setting to view on TV from HDMI to Ycp? (red blue green cables) now I can't see the PS3 menues, how do I change it back? can you help please My PS3 has no
    Genius:
  • Sony Master
  • 1,148 Answers
In the menu on ps3,,scroll down ,,find ,,display,,,in there ,,options to change back,,,goodluck
Posted on Feb 10, 2013
SOURCE: unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
you the man! that helped ssoooooooooooooooooo much!
Posted on Jan 07, 2008
SOURCE: no signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Posted on Jan 09, 2008
max30
  • 43 Answers
SOURCE: PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Posted on Jun 26, 2008
SOURCE: my ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Posted on Jul 09, 2008
Ravege
  • 327 Answers
SOURCE: My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Posted on Aug 01, 2008
I changed the PS3 setting to view on TV from HDMI to Ycp? (red blue green cables) now I can't see the PS3 menues, how do I change it back? can you help please My PS3 has no Red blue and green out
try taking out the red blue green cables completly out so no cables should be conected exept for the power cable then plug in the hdmi cable from the ps3 to the tv after you do that turn on the tv to hdmi input then turn on the ps3 and let it sit for a while and look at the tv while the ps3 is turned on shortly after you turned the ps3 on a message should pop up on the tv select yes then set the settings and that should work let me know if it dosent
Dec 08, 2012 | Sony PlayStation 3 (320 GB) Console
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
I want to connect my ps3 via hdmi cable to my magnavox 51mp392h/17 hdtv but theres no hdmi jack on my tv what to i do?
If there is NO HDMI on the TV, There are 2 options to still get HD. 1. Check if your TV has a DVI input, If it does you need a DVI to HDMI converter. This can be a problem with some TV models it might not sync up 100%. 2. I recommend doing this, Purchase the Component Cable For the PS3 from Best Buy or any Game store. Make sure it is the ONE for the PS3!!!!!!!!!!!!!! This cable will give you up to 1080i resolution and stereo Audio. Plug in the Red, Green and Blue into the Component (R,G,B) Input in the TV, The Red and White (audio) will follow into the same Input (White and Red) just match the colors from the cable to the TV. On the PS3 in the Menu go to the 2nd row from the Left and down to DISPLAY SETTINGS. Select Component (under HDMI) check off everything except 1080p and then SAVE by pressing X. If you have a Receiver (AMP) that your Audio goes into, Then you can buy an Optical Cable for Surround Sound. Plug in the Optical cable then on the PS3 go into the menu, 2nd row, Sound Settings, Choose Optical, Then choose Auto and SAVE! Hope this will Help!
May 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
No sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony PlayStation 3 (320 GB) Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
