Question about Ricoh Aficio SP C811DN Laser Printer
Error sc863-06 printer is suddenly showing error sc 863-06 what should i do
2 Suggested Answers
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
Que significa error sc 863 18?
HDD data read failure- q partition
Format the hdd or replace.
Apr 11, 2015 | Ricoh AFICIO MPC4000 MPC4501 SD YLD...
Sc 863-01 error
you need to go to copy sp mode by pressing
yellow C button and 1 0 7 and press and hold red C button
and go to copy sp and go to mode which is 5
go page down until you see HDD FORMAT
after that restart the machine
Apr 14, 2014 | Ricoh Aficio Office Equipment & Supplies
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Error 863-06
format the drive from the machines system and restart.
if this does not work call 0243494871 for the part or any other ricoh technician for help.
thanks and all the best
Mar 15, 2012 | Ricoh Aficio SP C811DN Laser Printer
I have a Ricoh Aficio 1045 copier that is not working today. It shows the SC863 on the panel. Does anyone know what this means? Thank you.
SC 863 is a startup without HD data lead data stored on the hard disk is not read correctly. or a bad sector occurred during operation of the HD this can be reset by turning the operating panel and main switch of then on again.
May 26, 2010 | Office Equipment & Supplies
My Ricoh Aficio copier 2051 the problem is SC 863-13 can u solve it?
SC 863 indicates that there are bad sectors in your machines hard drive. You have two options. First, try to have your hard drive re-formatted (you do this through the control panel in the service mode) but beware, any documents stored in the document server will be deleted and so will the scan to folder pre-programmed in the machine.
Second option, assuming the re-formatting did not work, would be replacing the hard drive altogether
Hdd formatting procedures:
service mode entry: press clear modes, press 107 then hold down the clear stop red button for 10 seconds, screen will then change. select copier, then upper right side select "sp direct" then punch in 5832.
Execute 5832 001 to format the HDD.
Jan 15, 2010 | Ricoh Office Equipment & Supplies
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
No.
Type
553
A
• Defective PSU
• Defective lOB
• Defective EGB
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN Laser Printer Logo
576 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
