Question about HP LaserJet P4015N Printer
10.00.00 supply memory error
50.10 error
    Champion:
    New Friend:
  • HP Expert
  • 286 Answers
This is a result of the cartridge not reading. Probably bad chip. Replace the cartridge
Posted on Jan 31, 2015
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP Laserjet M1522nf All-in-one Laser...
Supply memory error
remove the right hand side end cover ( formatter acces panel) remove the bad memory ( card about 1" by 3" )- if your not sure its failed try with new memory and see if error returns
Mar 04, 2014 | HP LaserJet M1522n MultiFunction Printer
Supply memory error
Remove cartridge, observe a small chip mounted on cartridge shell..This chip calculates the approximate toner levels, once its reached "Zero" printer says cartridge empty/low replace it.. If the memory is not detected due to any reason printer will say supply error or 10:xx supply error..
Replace this memory if available( locally its available ) or replace the cartridge.. Very few cases same error appears with faulty DC controller..
Ex supply memory:
Oct 28, 2013 | HP LaserJet P2055d Printer
Error 50
Error 50 clear memory. Black nk cartridge printhead ink empty.
Scan - check connection
Jan 25, 2012 | Brother MFC-465CN InkJet Printer
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
System we have here at work has BSOD 2x with xeskmdrv.dll error 50 blue screen - lookin for reason/solution on this
As you probably know, this is a Xerox printer module. Below is more info on Stop 50 but in general, you might try reinstalling the printer with the latest drivers.
Stop 0x00000050 or PAGE_FAULT_IN_NONPAGED_AREA
The Stop 0x50 message indicates that requested data was not in memory. The system generates an exception error when using a reference to an invalid system memory address. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause Stop 0x50 messages.
Possible Resolutions:
• If you added new hardware recently, remove and replace the hardware to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the hardware manufacturer to determine if the component has failed.
• Stop 0x50 messages can also occur after installing faulty drivers or system services. If the file name is listed, you need to disable, remove, or roll back that driver. If not, disable the recently installed service or application to determine if this resolves the error. If this does not resolve the problem, contact the hardware manufacturer for updates. Using updated drivers and software is especially important for network interface cards, video adapters, backup programs, multimedia applications, antivirus scanners, and CD mastering tools. If an updated driver is not available, attempt to use a driver from a similar device in the same family. For example, if printing to a Model 1100C printer causes Stop 0x50 errors, using a printer driver meant for a Model 1100A or Model 1000 might temporarily resolve the problem.
Sep 16, 2010 | Computers & Internet
50in samsung hd tv scrren wont turn on...red lights just keeps blinking
Change bloated caps on power supply pcb. You'll see them clear. That's should be it!
$10,00 for parts+ couple hours of labor and, you good to go!
95%. If you won't find any bloated caps, relax, it's time to get a new signal/main board. Can't fix those! Only replacement. Used one is ok.
My last case was a similar, 50" Samsung lcd panel with 4 1,000.00 mfd/16v.
good luck.!
Jan 23, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My 50 in plasma has seven red lights flashing please help
If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Oct 24, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Should i upgrade my power supply?
How powerfull is your powersupply? it should say on the side of the powersupply the wattage, for example 300W
if you can't find that please tell me the brand and model from the powersupply that read on it.
Jul 09, 2009 | Computers & Internet
Error 50
Do you have any more info? What happened before you got the error? Did the camera suffer an impact?
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
HP LaserJet P4015N Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
