Question about Konica Minolta Office Equipment & Supplies
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Displays error code c0500
  • Okorie Kodak Udemgba
    Okorie Kodak Udemgba Jun 08, 2013
    In one of the copier machines ( Di251) that displays the code c0500, I changed the heater lamp, in another, I changed the thermistor and in the most difficult one, I traced the problem to the board and changed one of the fuses and they all got reconditioned. Thanks for your numerous suggestions.
    Problem Solver:
  • 11 Answers
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Posted on Apr 17, 2013
4 Suggested Answers
  • 170 Answers
SOURCE: Konica Minolta Di2510 error code C0500,can not
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Posted on Nov 22, 2010
Nitrotrike
  • 589 Answers
SOURCE: minolta di 251
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Posted on Jan 11, 2008
  • 15 Answers
SOURCE: How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
I need to know m/c model
Posted on Apr 09, 2009
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Minolta dialta di 181 CO500 service call
Press the Trouble Reset Switch on the master Board for this fusing malfunction. Remove rear cover to gain access to control board, small little black switch, power must be on to do this be careful if the code come s back buy a new fuser unit, if you can find one. Quite old machine. DO NOT CONTINUE TO RESET the fuser can catch on fire that will ruin a perfectly good day.!!!!!
Apr 22, 2017 | Minolta Office Equipment & Supplies
The imaging unit needs to be changed
Buy new imaging unit, part #4163-612
then follow instructions here: http://www.manualslib.com/manual/611548/Konica-Minolta-Di-200.html?page=56#manual
Mar 11, 2015 | Konica Minolta Dialta Di200, 200f, 250,...
Di 251 code c0214
Power Supply, High Voltage Power supply or the Master Control Board, machine on a good surge protector if not after getting these part recommended you get one. Did you have a brown out or a black out. or electrical failure, 1st go with the Power Supply since that feed the other two, then the High Voltage then the Master board, all of this is predicated if you can get these boards the Di251 Series is a Legacy Minolta Series now Konica Minolta, good luck try below web site as a start to find parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2012 | Minolta Di251 All-In-One Printer
Probleme C0500 in konica minolta Di 1611
Hallow my friend that error is the problem of heater temperature try to check your voltage if is lower check were the voltage lost, or measure your heater lamps may be is fused, try to check all suggestions
Thanks
Jul 19, 2011 | Konica Minolta Di2011
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
MINOLTA DI ALTA 200 Y 251. NEEDS TO KNOW HOW TO MAKE IT SCAN.
well..the scan function is accessible from the main panel, OR the desktop manager. do you have a user manual for this elegant device?
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Minolta Di351 All-In-One Laser Printer
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta di 251 srror code coo7o
Jan 11, 2008 | Minolta DiALTA DI2510F All-In-One Laser...
140 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
