Question about JVC KD-HDR1 CD Player
JVC drains battery when OFF, puzzling
I had my JVC professionally installed. Several times if I left my car sitting for a few days it wouldnt start, dead battery. I pulled the fuse that supplies only the radio (now the JVC) problem solved. Figured it was a bad JVC head unit and got a replacement under warranty. SAME PROBLEM. Unit plays fine but will drin car battery if left for a few days (3) shut OFF. Car battery is very strong, only a few months old. Can sit for a long time with zero trouble if I pull the power fuse to the JVC.
Is there some installation error which could produce this battery drain when the unit is OFF? Hard to believe I got two new head units with identical issues unless it is a design flaw and if it was there would be stuff on the net about it and I dont see any.
Any answers or clues greatly welcomed.
Thanks,
Mark
  • 2 more comments
  • 377
    377 Jan 12, 2009
    Thanks. Goiod suggestion. Will try removing the head unit and leaving the fuse in. Will post results in about a week or so.
    Mark
  • kornycat Feb 14, 2009
    hello; i have exactly the same problem with my Ford Explorer and the JVC stereo different model; cd/satellite radio/usb/mp3 player. There is something in the unit draining my battery(battery brand new, replaced 2x). I had mechanics go over my truck with a fine tooth comb and conclusion is there is something wrong with the actual unit that seems to come on after it is turned off/in sleeping mode; jumps up to drain battery excessively. It is not the wiring to the unit that has been checked. Seems to just be this particular unit. This has taken over 2 years to have this figured out; back and forth to mechanic with various possible answers; battery; left interiour light on, left glove box open, alarm was tripped while parked, alternator problem!!! NONE of that at all!! Its the stereo that is the problem; so now what is wrong with these jvc units? mine was pretty expensive when I had it put in; professionally installed!!! thanks
    Kornycat@hotmail.com Anyone have any answers? I am ready to garbage the unit!!
  • sandor70 Apr 28, 2009
    I have a same problem, but my stereo isn't jvc. I found that it has two power intake. One from after ignition switch and the other from straight power for memory. As soon as I disconnected the permanent power the battery was starting the car no problem. But my car stereo needs that permanent power so what is the solution??? (sorry for my English)
    S.
  • highkey May 26, 2009
    I have the exact same problem with a cheap aftermarket stereo I installed in my daughter's Proton Satria 2001. I note doin12volt's answer as follows:
    "this HAS to be a problem with the head unit if the fuse ONLY goes to
    the head unit. Try this... Remove the head unit from the dash and
    un-plug it, but leave ALL the fuses in - If it STILL drains the batt,
    this is a problem with the circuit that the jvc is on, even though you
    think the fuse ONLY powered the stereo, it may go to something else
    causing the draw..."
    The power circuit that powers the radio also powers the clock, but it wasn't happening before I installed the head unit. So I suppose that means it must be the unit(???) If so, how can I tell that the next one I buy won't do the same thing?? My daughter is being very patient, but the problem itself is driving me insane.
    Problem Solver:
  • 8 Answers
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
Posted on Mar 03, 2013
    Sergeant:
  • 233 Answers
This HAS to be a problem with the head unit if the fuse ONLY goes to the head unit. Try this... Remove the head unit from the dash and un-plug it, but leave ALL the fuses in - If it STILL drains the batt, this is a problem with the circuit that the jvc is on, even though you think the fuse ONLY powered the stereo, it may go to something else causing the draw... I have seen MANY MANY cars that will list 1 fuse for the stereo memory, but if you trace the wiring you will find that circuit also may power cigarette lighter sockets, clocks, and many other "hidden" draws.
Posted on Jan 12, 2009
Why my car is dead after sitting for 3 days. when first hooked up jumper cables the interior lights came on then went off and wouldnt even turn over
If your battery is dead after 3 days it's probably getting stuffed or else you left something on. Anyway jump starting should work regardless. How good are your jumper leads? You need a pretty heavy set to start a car not those skinny things you get at super cheap auto stores. Hook them up and start car you're jumping off and run it at a high idle for about 5 min then try and start your car. That should put a base charge into your battery and it should go. If not buy a new battery.
Aug 22, 2014 | Cars & Trucks
Dead battery even when 2001pt,cruiser is not runing
You haven't given a lot of information to go on and I don't really get what you mean when you say the battery is dead even when the engine isn't running.
Have you had the battery tested? Most any parts store or repair shop can test a battery for you and tell you if it's good, bad, or just needs charging.
If the battery checks out okay poor connections at your battery could be the problem or the cables themselves could be so corroded that they no longer are capable of flowing current. If there is corrosion on your battery terminals that is a place to start. Use baking soda and water to clean the clamps and posts (you'll want to remove them for this), also a wire brush for tough spots.
Does the battery go dead after a few days or overnight? If after a few hours or overnight then something is most likely draining the battery. Do you have to jump start your car after it sits for a few hours? If so then look for dome or glove or trunk lights being left on, brake lights sticking on, aftermarket stereo or alarm wiring issues, or other items staying on after the car is turned off that would drain the battery. Bad door or trunk switches for the dome lights can cause the lights to stay on.
You can test for ignition off draw with the right testers to see if it's within specs. You could also pull the IOD fuse in the block under the hood to see if that stops the battery from going dead overnight.
If it goes dead over the course of several days then a more likely suspect might be the charging system.
But these are all just general ideas. We need more specific information to really hone in on any one area. But the first thing to do is get that battery checked and given a clean bill of health.
Jun 18, 2014 | 2001 Chrysler PT Cruiser
Cub cadet zero battery is dead after sitting a few days.
This is an electrical issue, you have a short in the harness, can very well be the keyswitch...even though you turned it to the off position, it's giving the unit the impression that it's still in the on position.
BriMaxSmallEngineRepairCo
Gibbstown,NJ
Jun 02, 2014 | Garden
2000 impala 3800engine when sits battery drains
If the battery goes dead in a few days, something is "on" and draining it.
Someone will need to check the circuits to find the drain. You can pull all of the fuses or check each circuit one at a time with a test light.
Dec 08, 2012 | Chevrolet Impala Cars & Trucks
Hello i have a 2004 expedition , and i have been having issues with my battery draining. about a month and a half ago i went away vacation , came home to start my truck only to relize my battery was dead....
Your solution is a little hard to find too bad they told you to change the alternator. It is a simple fuse you need to change that is blown. on the expetion sometimes there are two one in the fuse box and one under a black cover follow the alternator small wires it should point to the direction of the small i believe 7.5 amp fuse. it was hard to find and i do this for a living. good searching.
Apr 20, 2011 | 2004 Ford Expedition
Everything works great..However periodicaly radio wont work than battery dead after sitting for sometime.If i pull audio fuse [thats not blown]and re install fuse radio is fine and battery stays...
the radio is pulling down the battery, check to make sure it is install properlt, also make sure your battery is not weak, because remember the radio draws power at all time, to keep the time and your preset radio station. so check the battery for proper strenght first please.
Jul 31, 2009 | Hyundai Santa Fe Cars & Trucks
Brand new battery is dead with nothing left on. Bad ground?
Remove positive battery terminal from battery & put a 12 volt test light in line between cable & battery post. As long as 12 volt light is illuminated, you have a draw. Start pulling & re-installing fuses, one at a time,until you see it dim or go out. If it goes out, you found your draw. If it dims, slight draw, such as radio memory etc. if all else fails, make sure you know where they all go, then pull them all, and start putting back one at a time. When light comes on bright, you found the circuit causing the draw.
Jul 03, 2009 | Dodge Intrepid Cars & Trucks
Battery
have you had the alternator tested? it may be pulling your battery down when it sits for a day or so
Jan 21, 2009 | 2001 Lincoln LS
JVC KD-HDR1 CD Player Logo
1,632 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
