Question about Canon Digital Rebel XT / EOS 350D Body only Digital Camera
My canon 350d keeps coming up with error 05 everytime I try and take a picture
Error 05 keeps coming up every time I take a picture. I've tried turning on and off, changing settings, take the battery/smart card out and back in.
  • 1,511 Answers
Kindly format you SD card first then try again to take a picture .
Posted on Dec 08, 2012
IKnow
  • 68 Answers
SOURCE: Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Posted on Jan 07, 2008
thomtime
  • 38 Answers
SOURCE: Canon 350d not turning on/screen not working/
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Posted on Feb 09, 2009
SOURCE: Canon Digital Rebel XT: error 05
I had the sticking and two-clicks problem also. I manually pulled the flash up, then took a Q-tip dipped in standard rubbing alcohol and ran it over all the sliding mechanism parts of the flash. Then I rubbed the dry end of the Q-tip over it all agan and it now works fine.
Posted on Feb 11, 2008
old marine
  • 2128 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
Error code f5
There is no error code F5. Could you mean 05? That is a flash error
Feb 12, 2013 | Canon Cameras
I am recieving a error 1 message on my Canon RebelXT/Eos
ERR 01 is a lens communication error. Try cleaning the contacts on the lens and in the mirror box.
ERR 05 is a flash error. It is usually caused because the flash failed to pop up. This can be casued by something as simple as the flash hitting the brim of a 'gimme' cap or impact to the flash or most likely spillage of sticky liquid around the flash and its pivots.
The XT also is notorious for having the bottom right screw of the rear circuit board come loose and short out some function of the camera, or even blow the main fuse or damage the circuit boards.
Jul 12, 2012 | Canon Rebel XT / EOS 350D Digital Camera
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon eos 350d error 05, keep switchin on and off to correct but keeps reoccuring
is it also trying to release the flash when this happens? If so try and manoeuvre the flash a little by hand as it try's to open. once it opens its usually fine thereafter.
May 04, 2011 | Canon Rebel XT / EOS 350D Digital Camera
When taking a picture is clicks a couple of times does not take a picture and says error 05
Check if something is blocking the in-built flash to pop up or if it is stuck. If the flash is stuck press the flash pop-up button and try pulling it up simultaneously.
May 02, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel Error message E05
Go the the Canon support website and enter your camera model. If there is something you can do, it's there.
The E05 error says the lens is jammed or not working correctly. My guess is you need to take it to Canon.
This happens if sand gets in the lens or the camera is dropped.
Apr 21, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D flashes error 05 and flash won't pop up
I had the same problem but found that manually popping the flash up about 10 or 12 times restored the auto pop-up function.
Hope that this helps
Jan 13, 2010 | Canon Rebel XT / EOS 350D Digital Camera
CANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
Oct 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Open Questions:
See all Canon Digital Rebel XT / EOS 350D Body only Questions
Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
