I have a Amana tandem 7300 it starts beeping and stops working
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Dec 11, 2012
Power outage and the washer door is locked how do you unlock it
Posted on Nov 17, 2013
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
I have a Amana tandem 7300 front loader washing machine. It's stopped working nothing's happening except the display lights. Stopped in the middle of the wash cycle is there a reset button? Offbalanc
The only reset is to unplug the machine from power for about 5 min's and if that fails you may need to replace the washer timer control board.
Apr 19, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My amana tandem 7300 will not turn on any cycle it will go back to wash but does not turn on it just beeps please help if u can
It may think the door is open, front load machines will not proceed to fill if they cannot sense a locked door...
Apr 22, 2016 | Amana Washing Machines
Will not advance to wash after selection beeps on wash. But does not go on
Pump blocked .down at front of machine water willcome out so be prepared with towels etc.clear blockage
Nov 21, 2015 | Amana Tandem 7300 Washer and Dryer Stack...
Is there a DIY solution to my Amana washers problem?
It's a computer too. discommect it from power for 15 minutes and re-plug it. start initial setup again. Here is the link to the manual.
https://www.manualowl.com/m/Amana/NFW7300WW/Manual/206242tj3x46
Oct 02, 2015 | Amana Washing Machines
Amana 7300 tandem Dryer
Did you find a solution? Mine is doing the same thing.
Jan 05, 2012 | Amana DLE330RAW Electric Dryer
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Nov 28, 2010 | Amana Washing Machines
Washing Machines Logo
1,644 people viewed this question
Top Washing Machines Experts
