Question about DeLonghi Ovens
DeLonghi - DE91PYROS - 90cm Pyrolytic Multifunction Oven manual
4 Suggested Answers
  • 5 Answers
SOURCE: belling multifunction user manual
modle number 44445847
is that all you need?
Posted on Jun 30, 2009
  • 177 Answers
SOURCE: miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Posted on Mar 19, 2010
SOURCE: Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Posted on Aug 28, 2010
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Mile Pyrolytic Oven got a PY flashing
Mine is doing this too. Did you find a solution?
Apr 05, 2012 | Miele Ovens
My Delonghi DE60PYROS needs a new thermostat, are
Ok get a Service Manual, and the Sensor, and it is not too hard.
Mar 29, 2010 | DeLonghi AS1070 Electric Single Oven
Oven door is locked
its pyrolytic. if it hasnt finished embering the insides of your cooker (And usually meal) then the pyrolytic lock has failed (usually due to the pyrolytic 500* heat)
Feb 21, 2010 | Maytag Ovens
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Dec 28, 2007 | Electrolux EOC6690X Pyrolytic Electric...
Ovens Logo
Top DeLonghi Ovens Experts
ashburton
Jason Harris
Jason Harris
Brandon Berry
Brandon Berry
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
