Dynamic contrast error
I have nec m350x projector, when i start the projector it will automatically turns off and its status light blinks 9 times interval, as per manual this error is for dynamic contrast ratio, how to fix it, is there any way to reset the same
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Posted on Jun 23, 2008
SOURCE: NEC MultiSync VT540 not turning on - Temperature error
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
Posted on Mar 06, 2009
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
  • 89 Answers
SOURCE: NEC LT265 projector keep blinking status led
Download user manual from http://www.projectorcentral.com/NEC-LT265.htm
Posted on Aug 10, 2010
How can I fix a dynamic contrast error
Try cleaning the unit - I have seen a number of different symptoms when they can't breathe right.
Sep 12, 2014 | Office Equipment & Supplies
Projector M300W, with error Dynamic Contrast.
the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 18, 2013 | NEC Office Equipment & Supplies
My nec np-m300x has a dynamic contrast error. How do i repair this?
9 Blinks is IRIS error the motor can sometimes produce a clicking sound part number 24B17981. If you pull it out and manually move the metal apart the projector should come on and stay on
Jan 23, 2013 | NEC NP-M300XS- Xga Lcd Proj 3000lumen Shrt...
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
NEC VT676 lamp error
indicating ballast unit problem
Sep 11, 2008 | NEC VT676 Multimedia Projector
Status indicator blinks RED, not starting.
There are different rates at which the status light will blink to indicate various errors. See manual (link below) page 49 http://www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT37/vt37_manual_e.pdf
Jul 29, 2007 | NEC VT37 Multimedia Projector
372 people viewed this question
jasbo
jasbo
