Question about Brother DCP Office Equipment & Supplies
Where is the fuse in a brother DCP 165C printer
  • 164 Answers
SOURCE: My brother printer dcp-165C can't print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
n1wgk
  • 84 Answers
SOURCE: nozzle clogging on the Brother DCP-165C multifunction printer
take swabs and use alcohol to manually clean it...GENTLY and with not too much alcohol. You will go through several swabs. Use the foam swabs, not cotton, so you don't leave junk behind.
Posted on Mar 07, 2010
jbutler9
  • 132 Answers
SOURCE: How can I install my printer Brother DCP-165C
No problem, just follow this link, select your Operating System and language and download the Installation Software:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=dcp165c_all
Be sure to rate/vote
Posted on Apr 25, 2010
SOURCE: DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
Posted on Jun 06, 2010
  • 1382 Answers
SOURCE: I have a brother DCP-165C and it is not printing black.
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Posted on Jul 12, 2010
Error code 48
There is a problem on the print head, Please Contact Brother Printer Experts Brother Printer Support
Feb 25, 2014 | Brother DCP 165C Compact Color Inkjet...
My brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
my brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
Feb 15, 2011 | Brother DCP 165C Compact Color Inkjet...
I need the installer of brother dcp 165c
Here is the support page for your printer which includes downloads and more.
Brother DCP-165c Support
Thanks for using Fixya.
Dec 16, 2010 | Brother DCP 165C Compact Color Inkjet...
I lost my brother DCP-165c printer installer. where can i download online for free?
navigate to this link, you can download the installer of your printer
Nov 26, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Nov 21, 2010 | Brother DCP 165C Compact Color Inkjet...
How to reset brother DCP 165C unable to print
how can i reset my printer for brother dcp 165 printer..?
the erroe will appear in the computer is clean unable 5a...
Aug 18, 2010 | Brother DCP 165C Compact Color Inkjet...
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Nozzle clogging on the Brother DCP-165C multifunction printer
Mar 07, 2010 | Brother DCP 165C Compact Color Inkjet...
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
