Question about IBM Infoprint 1532 Laser Printer
Service fan stalled - IBM Infoprint 1532 Laser Printer
  • Stephanie Dec 13, 2012
    For more information it doesnt happen all the time. It happens if I havent printed in about 20-30 minutes
    Scholar:
  • 111 Answers
Is the Fan working or is it a false error?
Posted on Dec 27, 2012
Water Freezing Under Evaporator Fan
Check this site for more info on where the defrost timer might be.
May 05, 2008 | GE PTC22SBMR Top Freezer Refrigerator
927.03 service fan stalled
hello
This solution was tested for x 204. Get the right cover of the printer. See the fan. Fan connector is located to the card enters the socket. Socket located at the bottom part of the written 4R7. Install this part by removing the 4.7 ohm resistor. The problem is solved.
Sep 24, 2013 | Lexmark T642 Laser Printer
Fan error
This is an indication that a printer fan has stalled. Check the cable connections at J7 on the system board and at the main fan assembly. The main fan runs continuously when the printer is powered on unless the printer is in the Power Saver mode.
Dec 22, 2012 | Lexmark T630 Laser Printer
After a power outage the ice make didn't work. We defrosted and cleaned out all of the ice in the freezer and it still didn't work. Now there is water leaking out of the freezer and the fridge is...
The E/F error code is indicating a problem with the evaporator fan motor inside the freezer. It could be caused by a failed fan motor, control board or a loose wiring connection between the two components. The control board monitors the evaporator fan motor operation and speed. If the control board does not receive information from the fan motor or receives incorrect information because the fan motor has stalled out or is not running correctly "E/F" will display. This type of error code will require a service technician in order to diagnose the failure. I recommend calling a service technician to repair your refrigerator.
Sep 24, 2011 | Refrigerators
Lexmark X646e 927.02 Service fan stalled
This means the fan on the top of the machine, just below the scanner is not working or not working correctly. You will have to replace it.
Jan 06, 2010 | Lexmark X646e All-In-One Laser Printer
2003 chevy trailblazer....idlind at 600-750 rpms, when i engage the a/c it drops to 500rpms then stalls. also have two codes, p1481 and p1482. whats wrong?
The coolant fan clutch or the electric connections to the fan clutch is code1482.
Code 1481 is associated with the coolant fan problem but concerns the PCM having an error.
This error is why your car is stalling. The fan clutch is variable. When it is fully engaged the fan has more resistance and pulls down the rpm. The PCM is suppose to respond to this and raise the rpm for a steady idle. It is not doing it and needs a software upgrade.
The Chevy dealer may have a service note on this problem. The upgrade may be free.
Aug 24, 2009 | 2003 Chevrolet TrailBlazer
Car keeps Stalling
Is the check engine light on? do you have the A/C going when it happens? Is the car running hot? Possible places to look would be the intake air temp sensor, or the idle air controller. (if applicable). I have heard that some cars will kill the motor if the fan switch has died.
Jun 30, 2008 | 1995 Geo Metro
the defrost termination thermastat is what is cutting of before
time
it is located on the top of the evaperator in the freezer
part number is wr50x10153
the defrost timer is located in the fresh food section in the frount housing that the controls are mounted in
change the defrost termination thermastat and it will fixya
IBM Infoprint 1532 Laser Printer Logo
105 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
