Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Need package directions
A friend wants to borrow this wonderful machine, however i can not find the directions, that i would feel better about him having them. can you email them to me, or send them. thank you
  • 294 Answers
The Directions can be downloaded from the hoover web site.
Posted on Jan 13, 2009
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
Attachment Pole will not stay in down position and loses suction.
There is a wand catch that holds the attachment pole to the unit. It's above the power switch. It easily comes off and Sears has it for a pretty cheap price like $3. Without this wand catch the handle attachment pole does not stay put. Good Luck
Apr 01, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
I am borrowing a sewing machine Genie 354 and can not see how to reverse. Please advise?
The reverse stitch is connected to the stitch length function. Reverse stitching usually takes place after adjusting past the smallest possible forward stitch. At no time does the machine motor ever run in a reverse direction. Look for an adjusting lever that controls stitch length.
Aug 18, 2011 | Vacuums
Hi! I am borrowing this cleaner from a friend,
No, it just might need a new pump belt. When the belt is worn it won't dispense water or solution. Here is the belt you need:
Bissell 1699 Belt
Jan 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
A friend just gave me a Bissell carpet cleaning machine - but I need instructions on how to use it. My friend could not find the manual. It's model 1640-5. Can you help?
You can download user manuals from the Bissell website. However, if you look through the problems posted on this Fixya site under vacuums, you will see more relating to Bissell than just about any other make (with the possible exception of Dyson). You may then begin to wonder if your friend has really done you a favour...
Sep 29, 2009 | Vacuums
Atttix 8 Gallon AS/E
make sure your knob is set to the right hose diameter, the inner cage is properly seated inside the filter and your float is not being obstructed by debris.
Oct 16, 2008 | Alto 302000414 Attix 8 AS/E Canister...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
NoSuckage !!!
Either the lid for the dirty water tank is not completely on or the filter inside has been pushed up all of the way to the top. You need to have a 1/4 in. gap from the top to the top of the filter.
Nov 21, 2007 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
41 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
