Question about Makita Circular Saw - 15 Amp, 7 1/4in. Dia., Model# 5007FAK
Brush box cap replacement
I need a replacement brush box and cap
    Champion:
  • 304 Answers
I think you will find the brush box is part of the main housing.
Posted on Dec 14, 2012
Brush & brush caps for mercury m48 size please
hi, if you damage the brush inserts,I replacement for them, but that depends on location...
Regards
Dec 19, 2014 | Shoprider Health & Beauty
Replace brushes
In the middle of the housing set on both sides, there is a cap cover you have to pry off with a small screwdriver to get to the brush caps. Screw the brush caps off and remove the brushes (PN CB-430). If the brushes are stuck, pull on them until they come out. If the brush contacts/wires break off, you'll have to remove the armature and push the brushes through the brush holders. If the brush holders are damaged, replace the end bell, PN638448-2.
Mar 26, 2014 | Makita Angle Grinder BGA452
I have a pride 1170xl with E675HT motors. I broke the black plastic brush holder getting the brush out. Can the brush holder be replaced separately or do I need to buy the whole MOTOR END CAP? I may be...
Mark,
The manufacturer parts manual indicates the following information:
The motor brush caps are available from Pride:
PLSINDV1059 Motor brush cap (Reliance 0003-0035) retail $2.68
The brushes are:
DRVBRSH1000 Motor brush Jazzy (Reliance 0002-6957) retail $36.31
The guys in tech service at Pride (800-800-8586) are always a good resource for the information you may need. If you are exceptionally nice to them they will drop a new brush cap in the mail for you for free.
You can also check with Reliance Motors at their website for information and cross reference for other brushes available based on the Reliance part numbers above.
A good local motor rebuild shop can recommend a comparable (more durable) brush based on the specs. I think you may be disappointed with the pricing of the more durable brushes.
You can try on-line at:
http://www.graphitestore.com/items_list.asp/action/prod/prd_id/255/cat_id/37
Hope this helps.
Feb 06, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
How to replace brushes in dw703 cop saw
Remove the brush caps, remove the old brushes, install 2 of a part number 614367-00, replace brush caps. Let me know if you need any other help.
Nov 17, 2010 | Dewalt Saws
How to change brushes
Either side of the body are two round plastic caps with a slot in under these are a spring attached to the brush, what you need to do is unscrew the cap with a small screwdriver or the end of the collet nut spanner, and withdraw the spring and carbon brush, check the length of the brush and replace if worn down, replace the brush cap and run the tool without load for five minutes to bed the new brushes in. (if the brushes are ok make sure you replace them in the same orientation as removed).
Sep 02, 2010 | Dremel 395 Variable Speed Multipro Rotary...
My brush will not turn on my Bissell 6393 upright bagless vacuum... what is wrong? The belt broke and I replaced it twice... I now have 6 more replacements but the brush still won't rotate. Do I have to...
This type of plastic brush roll fails pretty frequently. Hair and other debis gets jammed in the end caps. The hair and debris gets hot which in turn tends to melt the plastic end caps. Remove your brush roll, hold the ends with your fingers and try to spin the brush roll. If it does not spin freely then it is probably damaged or clogged up. If it's not damaged beyond repair you may be able to unscrew the end caps and clean the debris out. If you can't unscrew the end caps then they may already be meted shut. Bissell part number for your brush roll is B2032305.
May 17, 2010 | Vacuums
Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
http://www.govacuum.com/biclandpobar.html
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
http://www.fixya.com/support/p49887-bissell_6594_powerforce_bagless_upright#manuals.
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
GoVacuum
Mar 23, 2010 | Bissell 6594 PowerForce Bagless Upright...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Reduction of runtime between battery charges.
The only other things I can think of is a bad motor brush, or a bad gear not turning freely in the gear box. I am not as familiar with the drive scooter, but it should have two caps on the motor that have brushes in them. The brush is held in by the cap, unscrew it and take brush out ( it is spring loaded) and check contacts. If it is worn down too much or unevenly worn it needs to be replaced, also if the spring is not set right or the brush is stuck it will cause drag, Put the brushes back in the same way you took them out if they are good, if you need to replace you need to wear them in by putting rear wheels of scooter up on something and run scooter by putting a rubber band on throttle. If it's the gear box it needs to be replaced
Jan 24, 2009 | Drive Medical Health & Beauty
I replaced the belt on my eureka 4870 vac and set it for carpet, but the brush will not turn?
Check that you have put the seal caps at the end of each brush roll side properly - it fits in usually with the arrows down the way, or if there is a triangular "angle" sitting, its how the caps fit into the sides - sometimes Electrolux/Eureka models have different caps on either side of the brush that need to be aligned properly as well as ensuring that the brush belt is on. Also check that the brush bar is completely clean. Hope that helps you!
Dec 26, 2008 | Vacuums
Makita  Circular Saw - 15 Amp, 7 1/4in. Dia., Model# 5007FAK Logo
51 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
