Question about McCulloch Chainsaw Shop Repair Manuals 121 Pages
What us the 'H' and 'L' on my chainsaw and how does it work
My chainsaw is PM484 No.0034830 and I am having trouble starting it I think it is probably due to my query
    Sergeant:
  • 137 Answers
I wouldn't mess with those High Low and idle speed knobs unless you know what you are doing. It is to hard to set them straight once you screw them in and out and lose track of your turns. The idle screw (T), might be Ok to mess with, but if you aren't starting, this won't help you. Try a shot of ether into the carburetor and see if it starts with that. If it starts, it means oyu have spark and probably compression. So you know it is fuel problems if it starts on ether. A lot of guys put to much oil in the mix and the mixture isn't volatile enough to burn and it just fouls the plug. Try the ether with a little choke but don't use the primer bulb. If the gas is bad or too oily the primer will just flood the plug. Try mixing the gas with about 1/2 the amount (1:20 ratio) and see if it starts. I always determine the correct amount of oil by watching the amount of smoke coming out. If I don't see hardly any smoke I add more oil until I see it. Since 2 cycle motors don't have a oil pan they got to get lubrication from the oil in the gas. So it is a fine line...too little oil and the cylinder runs hot and can be damaged from friction...too much oil and the engine is hard to start, especially when cold or trying to restart after it has sat for a while.
Posted on Dec 25, 2012
  • biire2u Dec 25, 2012
    sorry..i meant oil to gas ratio of 1:50 up to 1:80, not 1:20..
  • McCulloch Master
  • 2,239 Answers
There are 3 screws on the carb the idle screw usually marked with a T or an I, this screw contacts the throttle spindle and opens it to increase the idle speed, the L screw is a fuel screw, so by screwing it out ( anti clockwise ) will increse the fuel flow through the carb, the screw will adjust the idling, and acceleration up to half throttle, the H screw is also a fuel screw, this will adjust from half throttle to maximum revs, the max revs should be set with a tacometer to the manufacturers fast no load speed, small amounts of movment on boyh screws will make a big difference.
Posted on Dec 08, 2012
Can't start sthil AV34 chainsaw
Do you sitll have a good spark.? Have you increased the gap too much.?
Nov 12, 2012 | Stihl Garden
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
If my chainsaw starts but the chain doesn't
Its more than likley the chain brake has acttivated, grab the hand guard and pull it firmly fully back to the top handle, you should here a click as it loads, now try again
May 26, 2012 | Poulan Garden
Chainsaw won't start. Has spark, has fuel, chain
It starts but won't stop when switched off by stop button it's a husky55
Apr 04, 2012 | Homelite Garden
Stihl 023 trouble starting & running
Hi, Replace with correct sparkplug. You have a bad plug replace it and you're good to go.
Mar 11, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Trouble starting
You should check the carburetor to see if you don't have any vacuum leaks or gas leaks. You may have to replace the gasket under the carb. Before doing that , check to see if your choke is working right.Also check the filter and hose inside the gas tank to see if they are good. The filter unclogged and the hose not leaking.
If it is none of the above, the carb probably gave out. You may need a new one.
Feb 16, 2012 | Husqvarna Chain Saw Models 51, 55
I bought a chainsaw online VIKI PR-GS5200 and it arrived today with a manual in a different language other than English. I need assistance. Please help. Thanks
hi almenri i got the same chainsaw as you got had trouble starting it i found out that the on switch is off and the off switch is on do this and it starts straight away, and you can't get any manuel in english on this chainsaw as i tried to find one on the net myself glad i am machanicaly minded on any motor hope this helps you.Thanks Jason.
Sep 13, 2011 | Watches
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 | Garden
My chain saw won't start. I don't have a spark, even though I changed the spark plug.
The trouble is more than likely a bad CDI (Capacitive Discharge Ignition) module.
Jun 28, 2011 | Husqvarna Garden
McCulloch Chainsaw Shop Repair Manuals 121 Pages Logo
214 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
