Question about Philips DVDR3576H DVD Recorder
Playback on hdd gets stuck
Sometimes the recorded program on the hard drive gets "stuck" sometimes it will resume playing back, but sometimes not. sometimes i can do a "scene delete" and delete the part of the program (probably a disk error) that make it stick, then get the rest of the program to play normally. i also sometimes get some kind of recording error that results in a blank "title" with a red dot in the top right hand corner that is unplayable. i'm thinking of simply reformatting the disc. any suggestions?
  • scottshimamo
    scottshimamo Dec 10, 2012
    please take a look at the screen image from the titles view.. title 61 is a blank title that cannot be deleted no matter what i try. title 66 is acting normal and is currently recording a show.. i want to delte title 61.
Flashing red cassete light mean
So.... Who uses a VCR any more. They are ancient history.
They don't last forever so perhaps it's time to think ahead....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. I got him a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Cheers
Good Luck
Maybe you can get a little more life out of that VCR still
Aug 15, 2014 | Toshiba W522 4-Head Hi-Fi VCR
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
HDMI Digital Output
Parental Control
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
Swan dvr wont record
It sounds like a problem that might be an easy fix. Since the system CCA board doesn't see the HDD. Can you view any previously recorded images? How are the connections to the drive? Bad IDE ribbon cable (yes do do fault), power to the HDD and how about the drive? Some of my DVRs require the manufacturer drive, not a simple off the shelf (i.e. Lanex or Verint).
Try that and reply back. :)
May 22, 2013 | Home Security
I am unable to playback from the hard drive.
To confirm you really have programs there, record a new short clip and try to play it back.
Aug 29, 2012 | Toshiba Rdxv60
DVR will not record to hard drive
I did a (General Settings) RESET. Then I erased all programs on the HDD. Presto - it now records to the HDD a-ok.
Dec 19, 2011 | Philips DVDR3575H/37
My Magnavox MDR515H HDD recorder usually records the programs perfectly. But sometimes the tuner loses the cable signal and the playback goes blank during the recording. I have encountered this a couple...
Actually sounds like the feed for your HDD is going south on you. I would get another recorder to verify this scenario. Or, you could supply a local signal to the HDD to verify the problem. Use a VCR, DVD player, or the like to check it this way. The outputs from most local sources will be copy-protected, but you'll have Some signal.
Aug 29, 2011 | Televison & Video
Trouble with my recorder on screen display show HDD Fail and when we try to play is blank what we must to do.thank you regard riyanto
The hard drive for the recorder is bad. That's why nothing plays during playback. The DVR can't get the video off the hard drive. You'll need to send the recorder in to be repaired and the hard drive replaced.
Mar 08, 2011 | Samsung 32 Channel Network Video Recorder,...
Playback on PC has no sound
Are you playing the video back through the camcorders utility ? Sometimes by clicking on the file through windows explorer you will get the picture but no sound, this happens for the Sony camcorder but is fixed by running the playback through the motion picture browser application supplied with the camcorder.
Oct 24, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Philips DVDR3576H  DVD Recorder Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
