Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
LCD Screen jumps around after 2 minutes of use. It does not effect the end result though. I also notice an opaque pixel wave that cuts across the screen at all times. This started happening about 2 months before the LCD screen jumping began. Is it a software problem or an LCD replacement problem? Thanks, manuelwawa
  • Walter Manuel Jun 12, 2007
    Hi Thank you for assisting. I only have a camera reset and not a factory reboot that I know of. I have an extensive manual but no where does it indicate factory reboot. I will try Olypus germany.
    Genius:
  • 2,985 Answers
When you say the screen jumps around -I assume you mean the image not the actual screen it self. There are so many model out there it is impossible to be definitive. Try both of these 1. check the manual out and see if there is a 'Reset to factory setting' mode If not check out the Olympus Technical Help team at the Olympus web site. I have heard it said that the U.S. Olympus are not very helpful ,so if you can, try to locate Olympus Europe [based in Germany] I is almost certainly not a 'repair option,
Posted on Jun 11, 2007
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
Mar 21, 2013 | Toshiba 32AF45 32" TV
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
My lcd has 3 black lines, around 10-12 pixels up 3 days ago, and now it affected the pixels around it, in a span of 3 days, it multiplied to around 80 pixels that's just dead. what do i do? i dont want...
The only option in your case is to have the LCD replaced so Istrongly suggest you take it to your repair man. A reasonable price for that type of repair isabout 50 dollars plus the cost of the screen. You may find a price in the rangeof 50 to 100 dollars plus the cost of the screen though. Any more than that and I would find adifferent repair guy! Ebay is the best place to find the cost of your screen,just type in you model number and add the letters "LCD" to the end.
Jun 22, 2011 | Computers & Internet
Vertical line and shadowing on samsung 32"lcd tv
Clean the connectors from the main to the Tcon along with the flat cables that go to the panel, next would be repalce the tcon board,if that doesn't fix it you may have a bad panel
Dec 28, 2017 | Samsung 32 in. LCD Monitor TV
Blue wave across screen
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
Shadows and Ghosts on the Screen
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Akai pdp 4273m 42
I cured the problem by placing a fan in front of the screen that not only blows directly on the LCD screen, but also air underneath the screen providing circulation around the entire unit. Apparently the LCD screen is overheating causing it to "trip". I can stop the blower after about 20 minutes and there is no problem.
I will never buy another Westinghouse product again as long as I live.
Oct 15, 2007 | Televison & Video
Samsung LCD TV shimmer problem
Are you sure this is not an LCD screen door effect, It is a normal thing for this to happen to an LCD TV set. They are not made to be watch too close or you will magnafy this normal effect with the screen. If you have a problem with a new set, dont waist any time and get it service right away as it will cost you a small fortune in the future to have it serviced. Good Luck
Mar 24, 2007 | Samsung LN-R409D 40 in. LCD Television
Faint Horizontal Line
Your problem could be a bad LCD screen, and beleive me will get worse with age. It could be a Driver IC is not putting out the proper drive for that matrix of TFT. If you have a warranty, stand by your guns as its not right, so call and have the servicer make it right. Good Luck PS please do not forget to rate this thread.
Oct 22, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
52 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
