Lg 50pc55 plasma- has sound but no display??
My 50pc55 tv worked fine until recently when I turned the set on and had the green power light on but no display. Plugged in an av input and sound works perfectly too. Replaced the y-sustain and buffers, but there was no change. If I leave the tv on for a while then turn it off and on again I get sound and the display just shows a pink and green fuzz. Examined the set again and the PSU board has several blown and leaking capacitors that inevitably make a sizzling noise when on. Question is could these caps be causing the tv to power up but have no display / occasional fuzzy display?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Quite possible-----replace all bad ones and also if possible the voltages coming out of that board need to be tested---to be honest other than the caps it sounds like a main board issue. The set may have been run too long with the bad caps.
Posted on Dec 08, 2012
2 Suggested Answers
SOURCE: LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Posted on Oct 21, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
TV TURNS ON BUT NO DISPLAY AT ALL.
do a reset by manually holding down the power button, sometimes that works
Jan 28, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
No display issue
Red means it is going into shutdown because something is wrong.
It will not come on again until problem is found and corrected.
What is model number and do you have a warranty?
Mar 12, 2012 | LG 50PS60 50 in. Plasma HDTV
My LG Plasma 42PC3D turns on and off repeatedly. I turn on my FIOS set top box first and than the TV and it turns on and off repeatedly (front bottom display goes red and green, red and green repeatedly)....
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Sep 24, 2010 | LG 42PC3D 42 in. Plasma Television
JVC PD35D30 Plasma won't turn on anymore...
Yeah, I was going to suggest power supply issue. Plasmas IMHO, are not worth spending the money to fix. Its the reason why they are so cheap these days in comparison to LCD's. I had a 50" Samsung Plasma that went out on me within 2 years (E Buffer board and XMain problem). Its not about the manufacturer but more about the Plasma technology. Do a few searches about plasma and you will find a lot of problems with these tv's. Id say cut your losses, sell the TV for parts and buy a more reliable technology
Jun 07, 2010 | JVC PD-42WV74 42 in. Plasma EDTV
I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Sep 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Set turns itself on and off with no picture nor sound
You have a major problem with this set. Could be the main board, the Y-SUS board, or the power board or some combination of these.
Mar 30, 2009 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
