Replace a lamp on a photocopier
Photocopier Model: Minolta EP 2100
The lamp appears to have blown. Do you know how to replace a lamp on this model. When I turn it on to warm up after about 1-2 minutes it flashes an error code C5.
Thank you.
  • martin740 Jan 12, 2009
    Thank you so much for your reply. I am a complete novis with photocopiers so struggling a bit still. Although I have replaced the drum and blade on this machine before I am unfamilier with the fuser. Do you know where it is located and a brief description?
  • 469 Answers
C5 is the heater lamp in the Fuser assembly, the lamp is fairly easy to replace, but I would check he thermal fuse first.
Posted on Apr 14, 2009
    Novelist:
  • 126 Answers
Hello, the C5 code will only show up after the C7 code -- Fuser temp. to low. First put a meter on the Thermal fuse and the Thermistor and see if it is blown. The fuse and thermistor are under the black ( usually) fuser cover which runs the lenght of the fuser. If the fuse and /or thermistor are blown, replace. The lamp will not come on if the fuse or thermistor are blown. If the fuse and thermistor are good then take the end cap off of the fuser ( usually 1 screw) and disconnect the brass (usually) from the lamp. Check the lamp ( continuity), is the lamp okay. If not replace the lamp. If all of these are good then check the Solid state relay unit ( usually in the lower right hand side looking at the back of the machine with cover off). If the relay is good then you have to replace the PWB-A, the main board.
Posted on Jan 12, 2009
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Is it possible to scan using 210 model scanner by network?
Yes, it is possible ti use Konica Minolta bizhub 210 photocopier as a network printer.For this simply purchase network card Model NC-502 for bizhub 210.
Dec 17, 2010 | Konica Minolta bizhub 180 All-In-One...
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Oct 03, 2009 | Minolta EP1083 CS/PRO Copier
Service code c37 appeared on my toshiba photocopier
C37 indicates Abnormal transfer belt cam motor.
U need to perform below checking:
(1) Check if the connector of the transfer belt cam motor is not disconnected.
(2) Check if the transfer belt contact/release switch is working properly.
(3) Replace the transfer belt cam motor.
(4) Replace the LGC board.
Feb 28, 2009 | Minolta CF2001 Copier
Minolta Photocopier EP2030 service code
This code is related to the exposure lamp, Either the lamp is burnt or the fuse, a small device in the carriage of the lamp, is blown due to overheating. The reset is made with the machine switched on and by pressing the micro switch (right bottom corner) on the main board ( back of the machine).
GOOD LUCK.
Oct 31, 2008 | Sharp AL-1217 Copier
81 people viewed this question
jasbo
jasbo
