Question about Acer Aspire Z3771-UR30P
Monitor periodically has flickering pixels but then they go away
I have a acer z3771 all in one computer. Every now and them I get a bunch of flickering pixels in a verticle pattern on my screen. They usually start off just a few and then spread all over in about 5 minutes. Once the whole screen is covered the screen goes black and then its back to normal. I just got this computer 9 days ago and I have up to 15 days to return it I need some advice please! What is wrong with my computer?
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
SOURCE: Acer AL1912 19" LCD Monitor goes black after power up.
The problem with this monitor is a leaking capacitor on the power supply board. It is the middle one at the top in a row of three. The value is 10V 1000uf. Common problem for these.
Remove 4 screws from back of display. The case can be popped apart with a small flat putty knife at different points along the two seams. Three latches on each side and two at top and bottom. Push and twist at the latch points. There is a metal cover over the two boards. Power supply board to left. Screws and plugs can be romved. Unsolder Capacitor and replace. Radio Shack probably has them. Maybe a couple bucks. Be sure the power has been off for a while. These also have problems with the button board and corrosion at ribbon cable.
Posted on Feb 28, 2008
SOURCE: monitor flashes display 2-3 times then goes blank on initial boot
Throw it out the window. Acer sucks.
Posted on Mar 19, 2008
Geekman
  • 32281 Answers
SOURCE: Blank screen on AL 2223W
When you switch on the computer and monitor does the monitor power light illuminated?
If not check the power cable, if the power light is on try connecting it to another computer, if it works on another computer then the fault is in your computer or a faulty video cable (try another video cable).
If the monitor does not work then it is faulty, if it is OK then your computy is faulty.
If the fault is in your computer, you didn't exactly pinpoint the nature of your fault.
Does the power light on your computer illuminated when you power up?
Does your computer actually boot up, does it give and beep code (count the number of beeps - 7 beeps usually means video problems, depends upon the type of BIOS)?
When your computer first boots up and you see POST information on the screen then nothing, it is most likely :-
1. The refresh rate of the video card has been set too high beyond the monitor's specification.
2. Video card configured with incompatible monitor.
If you computer fires up and the monitor is OK the you have a faulty graphics card, you need to replace it.
Posted on Nov 13, 2008
SOURCE: monitor goes black after a few seconds
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from allelectronics.com fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Posted on Dec 29, 2008
How to access my ACER Z3771 without password
If you have a Windows 7 system, log into safe mode by pressing F8 when your computer is booting up. Select "safe mode with command prompt" and press enter. Wait until the windows login screen comes up and then a command prompt should appear. Type net user in the command prompt and hit enter. Once you have done this, you should now see a list of all the users associated with the account. Type net user "Your user account name" and then your new password and hit enter. This should reset your password for the following user account.
Feb 27, 2015 | Acer America Aspire Z3771 Desktop Computer...
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
I have a new BenQ G2220HD monitor connected to my MacBook as an external display. Since I've had it, it's had problems such as flickering pixels, lines that flicker, screen goes gray and flickers and is...
Your onboard video card is going bad on you computer. Some shops may sale an external video device which can be installed in place of your onboard video and it will fix your problem. Average costs aer about $50. Before you try YET ANOTHEr monitor, please try to hook the computer up to a tv to see if the problem pesists, if so, it is time for the above video adapter
Jan 28, 2011 | BenQ G2220HD Monitor
My display flickering
1. Check the cables for lose connection in the connectors.
2. Check if there are interferences of magnetic fields from other gadgets.Yes, check if near your laptop, you haven't placed speakers, florescent lights, cell phones, radios and any other electrical device.
3. Check if there were any changes in the display settings like when some computers are upgraded from their original versions. For instance, many laptops that have been upgraded from Windows 95 versions to higher versions, have shown problems of flickering due to poorly calibrated refresh rate.
4. Many a time, it may occur that the pixels on your LCD laptop screen/LCD Monitors are damaged in certain area and so you're unable to see proper images. If that is the case, then you don't have any other choice but to change the entire screen and replace it with a new one.
5.To check if there is no problem in your video card, connect another monitor to your laptop through the VGA port. If it shows any faint images or jumbled images, then the main reason for your laptop flickering screen is your video card.
6. if you don't find that there is any other problem you can detect, there must be problems within your computer monitor screen, otherwise It is advisable to go to your laptop service center and get the laptop checked. If you find that your laptop screen is still in warranty period and you find problems of flickering, it is best to get it changed.
Rgds
Dec 29, 2010 | Acer Extensa 4220-2148 Notebook
Monitor flikkering .i will check the VGA cable and power cable both are properly connected but the monitor is flikkering .what i do
Answer Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Dec 14, 2010 | Acer AL1511 15" LCD Monitor
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
Answer
Jan 29, 2010 | Computers & Internet
Acer 1916w flickering
Its either going to be a problem with puffy capacitors on the main board or the lcd is going bad on it cause the backlight can't stay on.
The cost of fixing the monitor may be more then what a new one is worth but you wouldn't know unless you bring it to a repair shop and have them look at it.
Try another known working monitor to see if you get the same symptoms, if they go away then you know the original monitor is bad. if you get the same symptoms then the video card is bad.
Jun 26, 2009 | Acer AL1916W 19" LCD Monitor
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
Jan 06, 2009 | Acer X193W LCD Monitor
Flickering pixels
plug it in all the way thats how i did it
Oct 30, 2007 | NEC-Mitsubishi Nec Display Solutions...
Acer Aspire Z3771-UR30P Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
