The entire instrument panel is dead. not one single gauge even twitches and no lights ever come on at all. would this be a fuse issue or do i need and entirely new cluster for the car? if so, is a junk yard the best but also cheapest route to go?
I had the same problem with my 92 new yorker my over head consle didnt work so it was shorting out my guages if u remove the four screws in the overhead consle and carefully lower it down there is a little black plug with small wires about 4 or 5 if you unplug the little plug your guages should work but like i said my overhead consle didnt work and if yours does it wont hurt to try this option
SOURCE: 2000 Chrysler Voyager Instrument Cluster is dead
have you got a dimmer switch on your model to dim the dash lights. if you have it may be faulty. link the cables together if the lights work the switch is faulty. if you have not got a dimmer switch
your printed circuit on the back of the dash may be faulty or the plug in the back of the dash is not pushed all the way in. hope this helps
