Question about Fujitsu Siemens Business Line E18-1 18.1" LCD Monitor
Half display on my monitor fujitsu siemens scenicview a17-3?why?
3 Suggested Answers
SOURCE: fujitsu/siemens scenicview e-19-1 model 900p
Please excuse me posting this as a 'solution', which I rather think demands one knows what was wrong in the first place! Anyhow, I have fixed my problem with this monitor. As previously mentioned cutting JP13 didn't restore the blank display. BTW: JP13 is on the component side of the first power supply printed circuit board (PCB), its under the steel plate in the back of the monitor case, remove both plate and board mounting screws to get at it. But responding to someones previous suggestion, I went about replacing all electrolytic capacitors (caps) on this board, did this rather than just replace C10/C11 as its a bit of a fiddle to open/reclose the monitor case and I'd already done it twice by this stage and wanted to limit possible damage to cables/connectors etc by repeated dismantling of case. ANYHOW! result is that monitor is fixed (so far!), had it on soak for a week and am using it right now, so hopefully it will stay that way. Its fairly easy job to do if you have some PCB soldering experience, you'll need a small iron and a 'solder remover/******' (when removing old caps). Recommend you look at www.badcaps.net/forum for info on the capacitor values you'll need. I used recommended good quality capacitors - Nichicon and Panasonic. If anyone is interested I'll post the list of values I used but its pretty easy to extract the old caps and get the values from them. Hope this is of help, regards Phil
Posted on Nov 01, 2008
budmrtn
  • 11361 Answers
SOURCE: Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 13, 2010
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Brock
Sep 16, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
My Fujitsu-Siemens Lifebook S7110 display going black time to time. It's coming back after restarting and it's working great with external monitor.
The display may be going black because of IC's getting heated up,contact ur Provider and get the screen replaced if using an external monitor is irritating
Dec 20, 2009 | Fujitsu Siemens LifeBook S7110 Notebook
Indicator LED blinking, no display on Fujitsu Siemens L19W-2
I've got the same situation. I think it is old enought to break. I just can't turn on the light behind the screen.
Jun 15, 2009 | Fujitsu Siemens Business Line E18-1 18.1"...
Pixels look blurred on new Fujitsu Siemens 17inch LCD Monitor
What are you using as a interface between your computer and monitor? It sounds like you may be using a digital analog converter. Example would be a 15 pin dsub VGA to DVI adapter or vise/versa. If your using a purely digital interface like Display Port, DVI, or HDMI then you have a bad controller in your monitor. Try to do warranty claim if this is the case.
Oct 31, 2017 | Fujitsu Siemens Siemens B772-1 17" CRT...
Fujitsu Siemens Business Line E18-1 18.1" LCD Monitor Logo
74 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
