Question about Jl Audio 1000/1 Car Audio Amplifier
The low ohm light is on my jl audio 1000/1 amp how do i get it to come off
The power light comes on and so does the low ohm light and it makes a high pitch noise when connected to the speakers
High pitched noise in speaker
Could be an alternator problem. Bad ground wire or just old bad wiring.
If you have an amp then the power wire is to close to the speaker wire.
Aug 28, 2012 | 2006 Lincoln Navigator
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
Bought some speakers, they're big and heavy but they don't have any indication of what ohm they are, i connected my turntable and all i can get is a high pitch noise from the speakers and no audio...
most of the speakers are " 8 ohms " ..the very old German made ones are 4 ohms only ...
which RCA jacks did you connect your turntable to Receiver ?
if "phone" ,it requires without "PREAMP" output from turntable.otherwise you will ruin the circuits in Receiver and make high pitch sound.....
Try with any other input on the receiver (i.e AUX.) and test it...
unless your RCA cable broken it should work well.you can try with another cable..and remember to make a solid ground connection between turntable and receiver as well..it is a must.....
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
  1000/1v2
Rated Power:
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio:
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response:
5 Hz - 250 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
High pitched noise coming from speakers after installing stereo
you may need to use a power line noise reducer or if useing amps a rca line noise reducer
May 10, 2010 | Boss BV9560 Car Video Player
check your wires if they are too near some big power wires and move them away from these high powered wires or check your grounds and make sure its a good ground by scrapping the connection until bare metal. Also its a possibility rca's or wires are getting pinched or not fully connected.
Apr 05, 2010 | Boss BV9560 Car Video Player
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Noise coming from the speakers
The right speaker is not tighly connected. Check for
loose connection at the terminals, that causes to oscillate (high noise)
Oct 11, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
Jl Audio 1000/1 Car Audio Amplifier Logo
27 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
