Question about Safe International Cobalt Em-015 Fireproof Safe Digital Electronic Lock
How do you gain entry after 3 failed attempts?
I have forgotten my code and after trying 3 times the safe now flashes a red light and beeps. How do i get in?
2 Suggested Answers
lessmith49
  • 5 Answers
SOURCE: Lost combination Safe Guard Digital Safe
I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade.
Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
Posted on Feb 13, 2009
Im using same code since but now i cannot open my digital safe is noble H0850
The batteries could be too discharged to release the bolt locking mechanism so the key must be used to gain entry to replace the batteries and possibly reset the code.
The dry batteries used in an electronic safe last such a long time they are often forgotten until trouble is experienced. Once accessed it is often discovered one or more of the batteries have leaked and caused corrosion so extensive cleaning and sometimes repairs must be carried out before long life and reliability can be assured.
It is wise to refer to the instruction booklet beforehand.
Feb 09, 2015 | Home Security
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Jan 16, 2011 | Sentry Fireproof Safe
I have the rona keyless entry lock (with single numbers on the front to enter our code.) For some reason, I cannot get it to change the code and have since lost my instructions. Can you please tell me...
remove all batteries then press any button on the keypad 3 times.Wait 10 seconds then replace batteries.You should hear a long beep followed by a short beep then press and hold the 0 button for 3 seconds. Red LED should flash 3 times and you should hear 3 long beeps. Now release the 0 button. Now enter new Master code (4-12 digits) followed by the LOCK button.You only have 15 secs to do this. LED should flash green once followed by a melody tone. Good luck
Bob...
Sep 07, 2010 | Directed Dei Valet 561r Remote...
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
My safe is open i have key but need to change combination forgot original numbers and how many numbers i need and how to do it i have lost paperwork could you please help me i am not to clever at this i am...
You need to open the door and press the red button inside the safe, on the door, near the hinge. Yellow LED will go on. Enter your new code (3-8 digits) followed by the hash key '#'. Yellow LED will go off to indicate the new code has been accepted and stored.
If the new programming attempt fails, the Yellow LED will flash with 5 beeps. You must attempt you new code again.
Aug 24, 2009 | Kitchen Appliances - Others
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Safe International Cobalt Em-015 Fireproof Safe Digital Electronic Lock Logo
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
