Question about Maytag Neptune MAH5500B Front Load Washer
Mah8700aww doesnt spin - makes loud humming noise
Is the moter shot?  just put a new water pump in it 2 months ago.  this unit is only 2 years old!!!
SolutionGuy
  • 331 Answers
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
Posted on Aug 12, 2007
  • 114 Answers
SOURCE: Maytag MAV6000Aww washer-loud noise when spinning
Chances are it is not the tub. It is probably the transmission. It has been my experience that the transmission bearing starts to make noise. Look under the unit to see if you can spot any transmission oil. If there is oil, it's time to start shopping for a new unit.
Posted on Sep 27, 2007
Master_Tech
  • 770 Answers
SOURCE: maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Posted on Jan 27, 2008
  • 3 Answers
SOURCE: washer has water but doesnt spin frigidaire gl2940es
WASHER DRAINS BUT WILL NOT SPIN AT ALL
Posted on May 24, 2009
jonniewalker
  • 1031 Answers
SOURCE: Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Posted on Aug 20, 2009
Just bought new pump. My old one lasted for 12 years. New one is 4 months old and recently started to make a loud whine or screeching noise when operating. It works fine but is very loud. I have trouble...
Most likely the bearings on the motor are going out. 4 months is way too soon, but it is possible you got a lemon. Unfortunately I wouldn't expect the new one to last 12 years. It's possible but unlikely. You should however get at least a few years. If the shaft seal on the motor shaft between the impeller and seal plate failed then water can drip back along shaft and get into motor bearings. This will cause motor bearings to fail. Even if this is not the case the motor bearings can fail even though it is rare to do so within first year. I would contact the place you bought the pump from, or whoever installed it. It should have at least a one year warranty. If for whatever reason this motor is not covered under warranty and you have to replace it, I would consider rebuilding it. Normally I don't care for rebuilds, but if the motor is truly only 4 months old then rebuilding it would be a good option.
Sep 23, 2010 | Polaris Pb4 - 60 Booster Pump
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
My pump is making a loud humming noise and when I turned it on would not come on , just hummed. Tried again later and eventually came on but still making noise. Do I need a new pump. It is about 5 years...
My Sunterra pump made that noise and I had a problem getting it to come back on after unpluggin to clean pre-filter each time. It was not long after that the plastic impeller sheared in pieces (the pump was only 1 year old and thankfully under warranty) My guess is that this is fixing to happen to yours as well. You are lucky to get 5 years. There was no reason for mine to come aparts. Uunterra sent me a replacement pump which had been slightly re-designed of the same 2000 gl size and the new one jsut did the same thing (only 2 1/2 months old) I called them again which in the meantime will mean my pond going witout filtration once again. I am getting very upset about this and will be looking for a good deal on a different brand pump.
Oct 05, 2009 | Sta Rite Dyna Glass 1.5 H.P. 115/230 Pump
Maytag washer performa model pavt234aww, just now 5 years old. -Two weeks ago, it started making an intermitten "loud-funky" noise, but worked just fine. Today, it filled up with water and simply died. We...
i would concentrate on moter moters have a limit not replacable , the whole moter would need to be replaced also check the lid switch this can cause a intermitant issue . as far as fixing or replacing its a issue you need to weigh out .
Aug 10, 2009 | Maytag PAV2300 Top Load Washer
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Loud humming while driving 2005 toy. camary. had tune up and transmission filter and fluid changed 2 months ago, was fine for a while but started humming loud again this week?
Please check your tyres.
if it is due to the tyres put the front tyres to the rear part.check if the noise moves to the rear.did you just replace the tyres?
there are brands offering cheap tyres which make noise .
Jul 09, 2009 | 2002 Toyota Camry
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
Sep 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
