Question about HP Photosmart 5520 e-All-in-One - CX042AB1H
Why will my 5520 printer will not print black
Black ink was out and put new ink in and printer will not print
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 43 Answers
IT MIGHT BE THAT THE BLACK INK RAN OUT OF INK SO ITS NOT PRINTING IN BLACK.However try changing the ink cartridge... If you have already done so then remove the ink cartridge and the clean the copper contacts with a lint free cloth... then shake the ink cartridge and then put it back in. then check if it works... if it does not then remove the power chord from the back of the printer without turning off the printer... then press and hold the power button for 30 sec...
then release the power button and then plug in the power chord...
again try printing in black.. if it does not then follow the steps below..
press the setup icon on the printer >> go to tools >> Clean Printhead ...
after it is done again go to setup >> tools >>Align Printer
after it is done check if black prints or not..
if not then Press BL/TL/BL/BL Buttons, in sequence (BL- Bottom Left, TL: Top Left) >>Touch Support Menu>>
Press Right arrow for Reset Menu and Touch OK >>
Press Right arrow for Semiful Reset and Touch OK >>
Wait for unit to Power Down/Turn Off>>
Press Power button to turn the Printer On.
Check if it works or not... if it does not then service the product
Posted on Nov 08, 2013
I have a hp photo smart 5520 printer that won't print black after I put a new ink cartridge in. I tried a different cartridge but still nothing. Any ideas?
Did you try printing out a test pattern? Is the new cartridge that you put in definitely good? It seems that those things are programmed to self destruct after the expiration date and often they dry out since the ink is alcohol based and evaporates.
It is not the printer head because on HP units the head is an integral part of the cartridge so basically every time you install a new cartridge you basically have a new printer.
If a known working cartridge will not work on the printer then something is definitely wrong with your printer electronics. U can always try reinstalling the software that came with the machine as a last gap measure.
Sep 05, 2015 | HP Office Equipment & Supplies
Printing very slow and black ink Looks off color
what you do with any inkjet is take all the carts out
so you eject the carts position then remove the mains
so its stays in park
slide a bit of sugar paper {blotting paper} under the cart head
then put a large bit of cotton wool into the colours cart housing
and soak it through with 30-50mL of IPA from the local chemist
and then fold it all shut and place a damp towel over the printer
too let it all soak in
then once you remove the cotton and put new carts it will work
most printers have a soak away for old ink if you have an inkjet you have well used and well then replace it with a modern 70 quid all singing all dancing model
so repair with IPA or replace with new
i prefer colour toner ...laser prints
Mar 26, 2015 | HP Photosmart 5520 e-All-in-One -...
My 5520 all in one printer does not print black
did you try cleaning the head? or a new cartridge?
Tony
Jul 14, 2014 | HP Photosmart 5520 e-All-in-One -...
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
New Black ink in it and it still won't print in black
Printer not used for long time before? Ink dried inside head. Use spuit tube, connect to black nozzle. fill tube with cleaner. wait for 1 -2 hours.
Jun 27, 2009 | Epson Stylus C88 InkJet Photo Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Nov 21, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart 5520 e-All-in-One - CX042AB1H Logo
3,603 people viewed this question
Seeker5211
Seeker5211
