Question about Dishwashers
I have just moved into a rental with a fisher and paykel nautilus dishwasher. I have turned it on at the switch and it keeps beeping with F1 displayed
    Problem Solver:
  • 5 Answers
F1 display means Flood has occurred. Call the company for more assistance. Here is a link- http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/521766I_DW920_ugm_NZw.pdf
Posted on Dec 08, 2012
  • 76 Answers
SOURCE: My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Posted on Nov 18, 2008
jsrock516
  • 5911 Answers
SOURCE: dishwasher f1 problem on fisher paykel
All the information that I have found about this particular problem indicates that the "F1" error is a flood or overflow alarm. It's generally caused by a clog in the drain line and/or tub not sealing properly when closed.
If this is a drawer style dishwasher there is a lid in the equipment cabinet that must seat properly on the drawer when it is closed. If you place items in the dishwasher that are too tall for the drawer lid to seat properly, it will not seal and water will splash over the sides of the tub during the wash cycle.
Another common problem is a clogged or kinked drain line. Remove the drain hose and make sure it is not plugged. Check it at BOTH ends.
The alarm is activated by a float switch in the bottom tray of the dishwasher. Look to see if this is any standing water in the bottom tray. If there is any water, or signs of wetness, the alarm will not clear until it is dried out. I found a couple of recommendations to clear the alarm. The first involved removing the dishwasher from where it is installed and tilting it at a 45 degree angle to pour any standing water out. Another method is to dry the bottom out with towels as best you can, and then use a hair dryer to dry any residual water. I hope I'm on the right track with this and I hope this solves your problem. Post back if you have any further questions.
CAUTION: UNPLUG the dishwasher or turn off the breaker BEFORE servicing inside the cabinet.
Posted on Feb 20, 2008
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel Nautilus Dishwasher
F4 is a fault code telling the controller that the water is not heating up. This can be caused by either a faulty heater plate, a bad connection between the plate and controller, or the controller itself. If you wish to fix this yourself, changing the heater plate is a fairly involved repair and should be done by someone with a high degree of mechanical ability.
Posted on Dec 11, 2008
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Dishwasher is beeping. Also has an F1 with a
paano maviverify ung friendster ko e ayaw mabuksan
Jan 27, 2010 | Fisher and Paykel Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Nov 18, 2008 | Fisher Dishwashers
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
225 people viewed this question
Top Dishwashers Experts
Owen Barnes
