Question about Hotpoint RVM1635 Microwave Oven
Hoppoint Microwave RVM1335BC001 Error Code F3
Display has error code F3-interior light comes on when door opens-otherwise keypad does not respond
  • SumrLilli Jan 15, 2009
    I have the same problem - it followed my boiling peanuts on my oven for a 24 hour period. I thought maybe the steam from the boil caused some damage. Let me know if you have a solution!!
  • Anonymous Apr 09, 2009
    I also have an F3 error code displayed and my microwave will beep intermittently all day and night. Three long beeps. Can you help?
2 Suggested Answers
flatech
  • 111 Answers
SOURCE: How do you replace intermittent door switch on
Open the Micro door, and remove the air/Vent cover on the top if there is one, Usualy 2 screws on top or the middle of the cover.
Remove the screw holding the Controller board and then you will have access to the door switches 2-3 of them depending on Manif.
Also make sure you have the power unpluged befoe you do any of this.
Posted on Oct 27, 2009
Testimonial: "You haven't failed me yet. You guys are great!"
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    F3 error code ge microwave
    No, unfortunately the membrane keypad is not available as a separate part on this model.
    You would have to order the control panel frame, which comes with a new keypad already installed.
    The part number is WB07X10883 and you can get it for $86.82 here.
    In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
    Some connectors on the relays may have a lock:
    Nov 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
    The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
    please rate this help to keep us online
    Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Lights turn on and off, keypad is out of control, F3 Code appears in the display.
    F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
    If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
    So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
    We regularly repair such control units for customers nationwide by mail in about a week or so with a one-year guarantee.
    Feel free to contact me directly (and please remind me of your full model number) for pricing and more information & help.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    May 13, 2009 | Microwave Ovens
    GE Spacemaker JVM1430WDOO2 comes on by itself ~2min and F3 Code after
    This is almost certainly a failing keypad. The F3 code is the giveaway.
    If you want to replace it yourself you can get exploded views and parts here: http://tinyurl.com/gv383
    Otherwise, we repair this problem for customers nationwide for $39.95 plus parts, and this keypad runs about $80-85.
    We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Feb 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Oven error -f3-
    In most cases that code means you have a shorting keypad.
    If you could post the full model number, I'd be happy to point you to the best source in case you or a friend want to replace it yourself.
    Otherwise, we regularly repair these for customers nationwide for $39.95 postpaid plus thew cost of the keypad.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    Feb 11, 2008 | Kenmore 66312/66319 Microwave Oven
    F3 Error Message
    It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
    Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
    Hotpoint RVM1635 Microwave Oven Logo
    108 people viewed this question
    Top Hotpoint Microwave Ovens Experts
    William Miller
    William Miller
    Jim Thurston
    Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
