Question about Toshiba Televison & Video
When I turn on my rear projection tv & the tv is cold the color will float,the picture will shake side ways for about 15 minutes.what can I do to fix the proble?
Then when the tv warms up the picture seems to be fine. Do I need to replace bulbs , or color wheels?
    Problem Solver:
  • 19 Answers
You did not provide a model so I am not sure of the type of set u have. Wheather it be CRT, LCD, DLP or LED. My 1st guess regarding "color float" is possably the convergence board/section of your set. And the warming up issue could be the result of cold solder connections and/or faulty caps on 1 or more circuit boards. Search your model number through the internet for clues.
Posted on Dec 08, 2012
  • Chris tuck Dec 11, 2012
    I put in the model # for you to look at. Your input helped me but maybe I can get more info now.thank u for your time
  • 1694 Answers
SOURCE: 57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Posted on Apr 25, 2008
  • 135 Answers
SOURCE: Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Posted on Jul 09, 2009
  • 8457 Answers
SOURCE: black and white
The bulb is not the problem.Unplug,replug the tv about an hour.Reset the colors setting back to factory setting.The tv work,should be back to normal.Not than ur Signal tuner board have problems must replaced.
Posted on Jan 23, 2010
SD Tech
  • 14553 Answers
SOURCE: TOSHIBA 57H82 TV Blurry for 15 minutes till warms up
This is a model first sold 2002.
They have a history of the Hyper board failing. Usually noise or lines in the picture and the warmup time gradually gets longer and longer.
This board processes all signal from all inputs inside the set and is no longer available from Toshiba.
The only way to get one is from a national company called PTS Electronics who rebuilds or repairs them--cost for rebuilt board is about 220 plus shipping and part number for this model is:
Part Number23148024
I have a service bulletin with photos of the board on my computer.
It is a financial decision, not a job for the average do it yourself person to attempt.
Let me know if you have questions or need help.
SD TECH
Posted on May 03, 2010
SD Tech
  • 14553 Answers
SOURCE: Picture image is unsettled when
LINES or noise from left to right etc. This is a classic problem in a lot of these sets--that this clears up after a while is also typical---the period will gradually get longer and longer for it to become normal.
This set uses a Hyper board for all signal from all inputs---about two dozen tiny surface mounted filter capacitors on that board---they dry out and lose value---flat caps will when hot attempt to regain some of the value they should have.
Board is no longer available from Toshiba, only way to fix is remove one in set and send out for repair to someone like PTS Electronics.
I have seen experts try to replace the tiny caps--usually several are off value or open---cheaper to send board out. Last one I saw cost was about 200 for rebuild, keep in mind same problem will happen again in 5-8 years.
Let me know if you have questions and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 21, 2010
Zenith z56dc1d dlp tv picture works for about 1 minute then starts shaking and tv shuts off
You may want to get it in a rather warm room and or remove rear cover and use a hairdryer to warm everything up inside the Cabinet--with rear cover off look to see if the fans are dirty etc and if they all come on, if a DLP especially look at the lamp itself and the fan that cools it.
Dec 18, 2012 | Zenith Televison & Video
When I turn on my rear projection tv,the color will float & the picture will shake side ways. My tv is a toshiba 50h81 model ,also it is a HDTV as well .
it's capacitors on the three line board. difficult to replace. I would recommend taking it to A professional. It will get worse over time.
Dec 09, 2012 | Toshiba Televison & Video
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
