WASHING MACHINE DOES NOT TAKE IN WATER
When the machine is in it's bad mood - then: It will not take in water - but drum turns. Will not centrifuge. Door can not be opened (only manually by emergency handle) When the machine works and then suddenly fails - pump out can be done by selecting Pump & Spin mode but does not spin after draining. Things I have checked: Filter is clean. Water pressure to machine is OK. Motor brushes were renewed 2 years ago. Magnetic valve block (3 valves) is new (4 months) As all the problems came at the same time, I think the problem is to be found in one place - but where - is the question. Any one have a suggestions. Best regards PK
    Sergeant:
  • 291 Answers
Strictly for troubleshooting: check the inlet water hoses (where the two hoses connect to the machine) screens. Any interuption in water service can send screen clogging debris through your pipes. If screens are really covered clean them i.e. use a toothbrush, swish in a cup of water, turn the water on a teeny-tiny bit (keep your hands on that hose if using the last method.) Then try the washer. If screens only have signs of debris collecting then move-on that's not the problem. Although now is the perfect time to dig out the old gasket/washer and replace it. Garden hose washers work fine. Don't remove the screen to clean it. Don't crossthread when putting it back. Do not overtighten.
You didn't give a mod # so only assuming you have front loader that you can clean filter on (maytag, kenmore, whirlpool?) When you remove the filter can you turn the drain pump propeller with a finger? It should turn like an airplane prop, but easily. Does it feel straight when it turns. The stem of the propeller can distort and kick it off center. If that pump goes out it plays havoc with the whole works.
Also not sure about symptoms. Are you saying it works fine sometimes but occasionally acts-up? Dianosis is difficult without more info. Specifically Mod # and history of symptoms. Sorry.
Posted on Dec 08, 2012
  • 3 more comments
  • Peter Klinge Jan 08, 2013
    Hi Countryman
    Hi Countryman
    Hi Countryman. Thanks for your reply. The Machine is a MIELE W916 (front load). Yes, machine works perfectly sometimes but occasionally acts-up. All filters, pumps, water pressure etc. have been checked. Meanwhile another problem has arisen. So this must be resolved before I can proceed with the first problem. The machine is now completely dead - nothing happens when I turn it on. No light in display 3N1, no LEDs light up, no light behind the program selector 2N1, but the programme selector bulbs are gone in any case. I have measured that there is power to S1 pin 9 and 10 and the to T1 pin 5 and 6. (S1, 3N1 etc. are ref. to schematics no. TI 11-9.25.2.2) So now is my question,- what do I do next?
  • B.H. Countryman Jan 08, 2013
    Try checking the door switch and path to and from it. I am not familiar with your machine, but i have some frontloaders that appear dead when that switch fries. Keep in mind, sometimes door switches just need an adjustment tweek. So if it checks good make sure actuators are functioning as designed. I'd check switches for continuity with wires off. Then wire paths for continuity. Make sure the machine is unplugged for continuity checks.
    You may have this, but if not here is one of the best owner's manuals i've ever seen: http://www.miele.co.uk/Resources/Operati...
3 Suggested Answers
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
  • 53 Answers
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Posted on Oct 21, 2009
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Samsung WF7700N6W1 washing machine not draining
Could be a sock or something between the 2 drums that moves over the outlet hole from the drum when upright and trying to drain but moves away when machine is on its side. Get a flashlight and look through the holes in the inner drum and you may find the culprit.
A coin may also be stuck in by the pump blade, not always easy to see but worth a look.
Dec 22, 2012 | Samsung Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
