Question about Toshiba TP55H95 55" Rear Projection Television
When I turn on my toshiba rear projection tv the color will be messed up.but when the tv warms up the color will be fine.also when the tv is cold the tv screen will shake across the tv
The tv is also a HDTV 55"
  • 26 Answers
You have some bad capacitors in the power supply. Look for domed over capacitors.
Posted on Dec 10, 2012
  • Chris tuck Dec 11, 2012
    Can I replace them myself,I am rounded in all area where are they located at on the tv?Thank you for your time
  • Angie Cruise Dec 11, 2012
    They are on the power supply board, that is where the AC cord comes in.
ctf1800
  • 4402 Answers
SOURCE: Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 25, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Jan 14, 2008
  • 1030 Answers
SOURCE: Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
Posted on May 12, 2008
  • 185 Answers
SOURCE: toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Posted on Oct 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: color convergence messed up
you can get the convergence repair kit for your model that has both convergence IC and the six feed resistors at this link, The repair kit also has step by step instructions with pictures so you can do the repair your self. Heres the link.The 50H82 kit is the same for the 57H82, http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 01, 2009
Samsung hdtv plasma ringing noise
the echo is probably a expanded stereo or something that you have turned on in the menu under audio. do yourself a favor,reset all your menu settings. the ringing,could be something more,coil on the buffer boards??? Check out http://www.shopjimmy.com/ they have tech assistance plus the best prices
Sep 06, 2012 | Samsung HP-P5581 55 in. HDTV Plasma...
The menu screen for the tv comes on and off by itself, also a banner comes up on the top that says "demo mode Motionflow"
If you can get into the menu, find and disable demo mode.
I'm looking at the manual and I bet its in SETUP.
Sep 06, 2011 | Sony KDL-55V5100 55 in. HDTV LCD TV
I got the 55" just
Go to your menu settings, look for an "autoprogram" option. Select that option and let it run completely through. This will add all available channels and deletes all channels that don't have a signal.
Jan 06, 2011 | Sony KDL55EX710 55 in. 3D HDTV-Ready LCD...
The picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
Nov 22, 2010 | Vizio VF550M 55 in. LCD HDTV
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blue cloud
That's OK, I been provided you technical info about TV problem.
Jan 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 55" philips hdtv;it won't come on either by remote or button on tv
Does the power indicator blink? If so how many blinks is it blinking before it goes out?
May 04, 2008 | Philips 55PW9363 55" Rear Projection...
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Toshiba TP55H95 55" Rear Projection Television Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
