Question about Lexmark T642 Laser Printer
Realign the print on my Lexmark T642 printer
I need to lower the print my one or two points to better fit my labels
    Problem Solver:
  • 13 Answers
You can adjust the print registration settings in the Config Mode of the printer. I believe you hold down both the down arrorw and right arrow button when you power on the printer
Posted on Feb 06, 2009
My lexmark T642 printer is printer lines at the far end of my invoices. Is this just a simple cartridge replacement?
It can be the cartridge or the dual charge roller. This roller is located above the cartridge. Take out the cartridge and lower the front cover 1/2. then you can see the dual charge roller. Partnumber 40X0127
Dec 14, 2010 | Lexmark T642 Laser Printer
Message on screen reads: 920.26 Service Fuser Error. I've tried switching it on/off, still won't work and none of the buttons will cause the error message to dissapear.
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T642, the manual states you should power off the printer and power it back on, which you did, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Aug 22, 2010 | Lexmark T642 Laser Printer
T642 Laser Printer: How do I change toner to my Lexmark T642. I can't ...
Switch off the printer and let the printer cool down. Then on the front of the printer open the release latchand lower the multipurpose feeder then open the top cover by releasing the latch. You will be able then to pull out the print catridge. Hope this helps.
May 03, 2010 | Office Equipment & Supplies
Lexmark T642 printer keeps printing all pages with black lines on both sides of duplex
This is due to dust is accumulated on the tufflon drum. Clean the same will resolve your problem.
Revert back for more assistance.
Jan 28, 2010 | Lexmark T642 Laser Printer
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Lexmark T642 - print is very light
take the cartridges out and clean the spot they go into then clean them off also
Jan 19, 2009 | Lexmark T642 Laser Printer
Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Dec 12, 2008 | Lexmark T642 Laser Printer
Lexmark T642: Will not print text files in Linux
Sounds like there is something corrupt with the driver or the wrong driver is associated with the printer. Delete the printer from the computer, but leave attached. Download the newest driver directly from Lexmark and execute the download. The computer should then automatically re-install the printer.
please visit the link below to download the correct driver for your printer directly from Lexmark.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
use the product selector to enter your model number and operating system.
Sep 03, 2008 | Lexmark T642 Laser Printer
Printing Issue - Lexmark T642
Chip on toner is bad, try puting in old one to reset and switch it with new one, sometimes turning off and on several times helps.
Mar 12, 2008 | Lexmark T642 Laser Printer
You need to download the Postscript drivers from Lexmark site.
Oct 28, 2007 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
475 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
