Question about Akai PT5492S 54" Rear Projection Television
Sound works no picture
Tv was on and picture went out sound still works fine how do i fix cant find a repairman
  • 1 more comment
  • Anonymous Jan 13, 2009
    Same as above; sound works, no picture (PT 5598HDIX/SMS
  • clsomega2 Jan 13, 2009
    I have a Akia hdtv 1080i with sound and a black screen
  • babydoll94 Feb 07, 2009
    i had the cable guy come out and look at my tv, didn't know much really but he said cable is fine but my tv is black. sound works, channels change and all input seems to work but no picture....what do i do?
T.v sounds comes on picture not working can watch pip . sometimes when you turn the t.v the timer light in front flashes can u help
Posted on Jan 26, 2009
My hitachi Model recent quit working . No picture or sound. Red light does not come on. Sounds as if power supply went out but really not sure how to check. please advise. Thanks
So you can go to walmart buy a 50" TV for about $500. A power board for your old TV gonna run about $150 and the repairman prolly charge another $150 so why try fix the old one? TVs are too cheap to buy now so no reason fix an old ghost screen.
Oct 19, 2014 | Televison & Video
Sound went out. Heard a
if you using non-integrated speakers check the cable if integrated call a repairman dont open your TV yourself it's dangerous
May 28, 2012 | Televison & Video
No picture but have sound
That click might have originated in 2 places: either it was the main relay disconnecting or it was the sound of a capacitor popping. Both are very severe problems - they signal that the power source of your tv has just failed.
Fixing it is a job for someone with electronics experience, if you're not one then call a repairman.
Jul 26, 2010 | RCA P42WHD33 42 in. Plasma HDTV
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Mar 21, 2010 | Philips Magnavox MWR10D6 DVD Recorder
There is no picture, but there is sound from my tv
I would say that your speakers are obviously still working fine but your tube has failed. You could get it fixed but it probably wouldn't be worth the price the repairman would charge
Sep 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No picture, no sound, turns on, but turns itself off immediately.
unplug 2 ribon cables they are white then plug them back in  should fix it
Jun 08, 2009 | RCA HD52W66 Projection Television
Sound but no picture
The first thing to check is the connections to your source. They can easily become loose and/or corroded over time.
Feb 25, 2009 | GE 46GW945 46" Rear Projection Television
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
155 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
