Question about Yamaha PSRE413 Keyboard
Dead keys yamaha psr e413 keyboard
Two of the keys have no sound when press
    Guru:
  • Yamaha Master
  • 661 Answers
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Posted on Sep 20, 2017
  • 5603 Answers
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Posted on Sep 08, 2010
robocop
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: How do I take apart Yamaha PSR-280 keyboard to clean keys.
There are 17 screws on the underside of the keyboard that need to be removed. The base cover can then be removed. This gives access to the keyframe assembly which can be removed.
Posted on Feb 08, 2009
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Posted on Feb 10, 2009
  • 1126 Answers
SOURCE: yamaha psr 140 instructions??
http://www.usersmanualguide.com/yamaha_audio/electronic_keyboards_(portatone_-_portasound)/psr-140
Hope this helps.
Posted on Jul 09, 2009
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
No power to the switch but will power up with batteries
One of two most common possibilities are a non-functioning AC adapter or keyboard AC adapter connector next to the Power On Switch has a cold solder joint and does not pass voltage.
Nov 04, 2013 | Yamaha PSR-E413 Portable Keyboard
Yamaha 9000pro, Ps is ok but unit will not boot
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
Sep 30, 2013 | Yamaha PSR-E413 Portable Keyboard
How to fix Yamaha PSR 400 dead keys?
Normally this would be from dirty or broken key contacts.
Apr 19, 2013 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Power comes on but the psr 9000 yamaha does not boot up past the first page
The unit probably is detecting an error during the power on test... A long shot MIGHT be a button or key that is stuck on, that is sensed as being pressed. See if all the buttons are completly up. If the unit has a harddrive, a failure of it can block the booting even though the operating software is not on the drive in these. If you find a button that is sticking, put a tiney bit of CRC226 around it with a Q tip. You can get the CRC226 in the electrical dept of Home Depot. You just want to wipe the edges of the button to lube it a bit.
Apr 11, 2011 | Yamaha PSR-E413 Portable Keyboard
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha PSRE413 Keyboard Logo
116 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
