Question about Bose Wave music system Multi-CD Changer 3-Disc
How do I load cd into bose multi changer
How do I load cds into the changer
  • 1,258 Answers
The owners manual should tell you that- I think you just insert them.
Posted on Dec 11, 2012
  • 23 Answers
SOURCE: Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Posted on Mar 18, 2009
  • 23 Answers
SOURCE: bose wave muoti cd changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will have to be disassembled to get the CD out and the unit itself will need to be serviced (rebuild and retime cd changing mechanism)
  • 132 Answers
SOURCE: I have an older Bose Wave radio without a CD. Can
If it has another input then yes if not you will have to get a A/b switch.
Posted on Oct 17, 2009
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
  • 23 Answers
SOURCE: I have a bose wave
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Posted on Jan 30, 2011
Why won't bose play some cds
Could it be the CDs you can't play, are burned in a PC?
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 13, 2014 | Bose Wave music system Multi-CD Changer...
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
Can't use discs 2 through 4 of my Bose Wave System
The Wave Music System Multi-Disc changer can be a bit finicky sometimes. (especially from earlier runs of that model) It could have been moisture though. Bose tech support is who you want to speak with. If resetting it won't fix the problem call them (800-367-4008). I think they can repair this for $75 w/ new 1-yr warranty.
If you're trying to reset this to get a temporary fix, you don't have to remove the CDs. Just remove the power cord for at least 30 seconds. Having it force-eject the CDs (which it will do if you reset it) may actually clear up the mechanism. But this is just a hope.. I'm assuming it's not still under its 1-yr warranty, otherwise they will replace it for free.
Jun 10, 2009 | Bose Wave music system Multi-CD Changer...
Bose
PO Box 9168
The Mountains
Dec 01, 2008 | Bose & Wave& Music System
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Wave CD changer
Could try a CD lens cleaner disc, but this will just as likely get stuck inside. Far better to contact Bose for a repair - sounds like a problem in the changer mechanism
Dec 11, 2007 | Bose Wave Radio
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
Bose Wave music system Multi-CD Changer 3-Disc Logo
149 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
