Question about HP Pavilion DV9727CL Notebook
Hp dv9727cl laptop screen goes blank after a few min. How to check if mono,graphics, or inverter prob.
Laptop screen displayed all kinds of colors,and i was told that the screen needs to be changed. I replaced the complete screen and frame assembly and now the screen comes on for a few minutes and then goes off. If I cold boot the laptop again, the screen stays on a few minutes and goes off. It goes ff each time displaying for less time until it does not display anymore until I discharge all power and start again from cold boot. Could it be the inertia, graphics chip, or motherboard that is the culprit. Thanx
  • 29 Answers
Format your system
Posted on Dec 11, 2012
  • 55 Answers
SOURCE: HP Pavillion DV2000 (dv2415)laptop w
We can troubleshoot the Overheat issue but first we need to turn it on. Perform following steps and check if you can see the diplay on screen.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook power up and shows you display, then proceed with further steps (or you can connect a desktop monitor to check if its displaying. Press Fn+F4 to toggle the display on external monitor)
The notebook may overheat and make noise or stop working due to the following conditions:
1. Due to incorrect power supply from the AC adapter.
2. If the Fans/Heat Sink are not working properly.
3. If the power management and BIOS settings are messed up in the Notebook.
4. Finally due to other components on the system board.
To resolve this problem with overheating, perform following steps.
I check your Laptop and see that your Laptop product number is "GA534UA#ABA" with Windows® Vista Home Premium pre-installed, if you are using the same, process with following steps.
Step 1: Reset the BIOS to factory defaults:
1. Click Start, Turn Off Computer, Restart.
2. When the HP logo appears, press F10 to enter BIOS Setup.
3. Press F9 when you are in BIOS Utility to load the BIOS to default. Click YES. Then press F10 to Save & Exit.
Step 2:Re-install Power Management in Vista
1. Press Windows key + R
2. Type devmgmt.msc and press enter.
3. Click the plus (+) sign next to System Devices.
4. Right-click the ACPI Fixed Features button and select Uninstall.
5. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
Step 3: Installing an update for BIOS:
Caution: Install this BIOS only if you are using pre-installed operating system with above mentioned Product number.
WinFlash for HP Notebook System BIOS (for Notebooks with AMD Processors):
ftp://ftp.hp.com/pub/softpaq/sp43501-44000/sp43666.exe
Step 4: AirVent cleaning:
Reducing Heat and Fan Noise by Cleaning Air Vents:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01657439&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
In case there is no display, remove and reseat the Hard Disk and RAM and check for the issue. If display comes up after removing and reseating the RAM and HDD, then you need to follow the above steps again.
Service Manual to remove reseat HDD and RAM:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Memory Module Page: 127 of 310
NOTE: If you have more than one memory module, you should test them individually to determine if one or both of them are faulty. Insert each module separately, then turn on the notebook to determine if the inserted module is working. Once you have determined which memory module is faulty, you can replace the faulty module and reseat the working module.
Hard Disk Page: 121 of 310
Contact HP at www.hp.com/support/chat for further assistance.
Posted on Aug 22, 2010
  • 928 Answers
SOURCE: HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Posted on Sep 05, 2009
KatFishGR
  • 90 Answers
SOURCE: compaq laptop display not working
Have you tried an external monitor? Plug one in while the laptop is off, then turn it on. If no video on the external monitor, then there's a hardware issue somewhere else. Such as ram, motherboard or possibly cpu.
Posted on Oct 26, 2007
  • 788 Answers
SOURCE: HP laptop display issue
If you are recving 1 long and two short beeps, it is not a memory problem.
It is not a Lid closing or lid switch problem.
If you are able to switch to and from your LCD and Monitor, you are lucky.
I have been up and down the road with several HP DV6000 series units, all have had the 1 long and 2 shot beeps.
HP is aware of this problem and has offered an extended 1 year from date of original warranty expiration. Another words 2 years from date of purchase. HP will ask for $365.00 + or - ? for this repair.
Their repair consists of a motherboard replacement.
If you go to HP's web site, you can look up your model and if in warranty, have it sent back for repair.
The problem will not get better in time but only worsen. The heat sink on the dual core units is not handling the heat transfer properly.
The board is a 2 sided wafer which has displayed failure in several places, due to the heat load and transfer design. Area of problem is directly under NVIDIA chip look for craters. Theses are solder points the size of a pins head which because of the heat and the stress of the transfer bracket above, have separated making in some cases an intermittent connection to chip.
The best thing to do is have a technician remove the board from inspection and blow out the heat sink and surrounding areas.
Apply new heat sink tape and grease where needed and re-assemble.
You must update your BIOS ver. to current.
This new version will address the Voltage and Fan Control Speeds in a better manor.
If your unit is just now giving you these errors, now is the time to act.
Just like in a A/C unit at home, a restricted air flow will make unit run longer and hotter.
Their are no filters here, once lint and dust have collected in the coils, it is just a matter of time.
Hope this helps you in your problems.
Anybody reading this note having a DV6000 series unit, should check at their web site for warranty and call back issues.
John
john@johnrraycomputer.com
P.S. if you are a technician and feel you want to repair the board yourself, drop me an email with the model number and I will explain in more detail.
Posted on Jun 11, 2009
SOURCE: hp dv6000 laptop beeps 4 times n won't display on start up
I had the same problem, i found it was because my RAM stick was installed loose. I removed and fixed it again properly.
Issue was sorted.
Posted on Mar 29, 2010
Blank display on HP dv2000 laptop
i suggest you dismantle your laptop and take a look at the LCD cable behind the screen and make sure it is click locked.
Jan 23, 2013 | HP Pavilion dv2000t Notebook
Power on but no display
try to plug in an external display and see if it works, if not it's probably the video card.
Aug 02, 2012 | HP Computers & Internet
My hp laptop screen is blank on start up
Due to the problems in the inverter or due to the troubles in the cable connection usually screen flickering happens in the display of HP Laptop. As the inverters are responsible to supply power to the back-lit of the screen, any problem in the inverter would create troubles. By replacing your inverter and by checking the connections of the cable in your HP laptop, this problem could be easily resolved.
Get more help to fix HP Laptop Display Issues . Hope this helps you.
Regards
Michel
Jul 07, 2011 | HP Pavilion dv6000z Notebook
Blank Screen , Power light comes on and all lights right under screen (sound and media playerand touch pad lights) come on and stay on. disk drive works and no secondary monitor display.tried the battery...
If you have checked all functions as you described and a remote monitor, then the problem is the graphics card on the motherboard, in most cases the motherboard must be changed because the graphics card is built in.
May 13, 2011 | HP Pavilion dv7-1130us laptop
The LCD screen of my Hp 6735s only flash immediately after putting it on but goes blank afterwards.....i have checked the inverter board ,it is intact....
it's proabably the graphic chip on your motherboard but unfortuantely that's built in so you might need a new motherboard
Jan 09, 2011 | HP Compaq 6735s Notebook
Laptop display goes blank after a second, not lcd inverter
I have had a similar issue with an LCD monitor and the issue was not with the inverter itself but the backlights. They can go bad and short (which is where my issue was. Once they were removed the screen was working again (the lights needed replaced).
Hope this helps!
Nov 08, 2009 | HP Pavilion tx2500z Notebook
Startup problem
Try to plug it with external monitor and check again is it working with external monitor , then check display adopter driver of your laptop , re-install the VGA driver,
If this thing find use full kindly send comments
Mar 26, 2009 | Dell Inspiron 5160 32MB DDR AGP Graphic...
Display problem
you have to open the chasis of the notebook and resit the ram if the problem is not solved then your notebook needs servicing
May 28, 2008 | HP Pavilion dv1000 Notebook
The screen goes blank at start up
If you can not see anything, then it may be your inverter (Replacement part cost is around $50.00), if you can see a dark image then your CCFL (Cold Cathode Fluorescent Lamp) is out. (Replacement part cost is around $15.00)
Check websites like http://www.ccfldirect.com/
Oct 16, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion DV9727CL Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
