Question about 1999 QUEST Base Vacuum hose
What is the hose next to the starter foron a 94 nissan quest
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Water drain
Posted on Apr 24, 2014
What other motor are the starters compatible with a 94 Nissan quest
Well the starter is used on Quest models from 1993 thru 2002, and some Maxima models from 1992-1994. It also is used on Mercury Villager models.
Jul 28, 2014 | Cars & Trucks
How do you replace fuel line to nissan quest
get the new line.
bleed the old one because fuel is under pressure.
I would start under the hood, remove fitting, pull apart hoses.
run the new hose next to the old one.
connect under hood first then remove connection at gas tank.
attach hose at fuel tank. If there is an inline filter replace now will
save time since you are already under car.
Next pull old hose out and throw away.
Last push hose onto mounts from old hose. If they break use cable ties so hose stays in place.
enjoy your car.
Mar 04, 2013 | 1996 Nissan Quest
How do i access the area to change my power steering hose on 2004 nissan quest
how do i access the area to change my power steering hose on 2004 nissan quest
Feb 24, 2013 | 2006 Nissan Quest
94 nissan quest front left brake locks up replaced front calipers and bleed the front same problem
I ran into that problem and it was because I put a pair of vice grip on the rubber brake line and it tore the inside of the rubber hose and wouldn't allow the brake fluid to return to the master cylinder, I don't know if you have the same problem but it's a idea.
Aug 26, 2011 | Nissan Quest Cars & Trucks
Where is the 4 channel amp located in the 94 nissan quest.?I am trying to install a stereo and there is no sound due to the amp. I need to know how to wire with the built in amp.
I just installed an after market radio in my 94 Quest.
The easiest way is to buy a Nissan Quest Radio Wiring Harness for Premium Sound. It will have the complete wire hookups. You can also hook up the blue wire from the new radio to thefactory (I think Blue or Blue/White) wire on the harness. That will turn the factory amp on.Hope this helps ,good luck
Jan 07, 2011 | 1994 Nissan Quest
Need to no how to change starter in 1998 nissan quest
There are many small steps in this process. Do yourself a favor and buy a service manual on CD over on ebay. That way you will have text and pictures and a resource for your next problem. If you can buy a tank of gas, you can afford a manual on CD.
Nov 18, 2010 | 1998 Nissan Quest
Nissan Quest 1996 won't start. Battery good.
tap the starter at the same time turning the key. if it starts ,replace starter.
Mar 14, 2010 | 1996 Nissan Quest
94 nissan quest has started idling at 500 rpm. I
Jeff did you figure this out. I am dealing with the exact same thing currently. Things to look at are Mass Air Flow Sensor (MAF), Throttle position Sensor (TPS), Air Idle control valve. I have played with everything but the Air control valve. I tried three different MAF, including a ghost sensor (circuit to match ressitance). I'm going to investigate the air idle control tommorrow. Let me know if this helps or if you get it figured oot
Nov 01, 2009 | 1994 Nissan Quest
Nissan Quest 1994 Overdrive Problem
if you leave the O/D off, what happens?
Go here and read files too.
http://autos.groups.yahoo.com/group/villagerquest/
Jun 09, 2009 | 1994 Nissan Quest
Nissan Quest Van 6 cylinder XL
I need a diagram of where the starter is in a 94 nissan quest van
Oct 17, 2008 | 2000 Nissan Quest
1999 QUEST Base Vacuum hose Logo
136 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
