Question about Sanyo Cameras
Lexor sd card Locked in camera
It says card is locked and I cant take pictures?
  • 4,738 Answers
Actually there are several possible solutions to this problem, Troubleshooting steps may be viewed here:
Posted on Dec 08, 2012
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sanyo Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
5 Suggested Answers
Doodad
  • 64 Answers
SOURCE: locked memory card
There is a tiny switch located on the side of the memory card, might even say lock on it or beside it. Just flick the switch opposite of the way it is now and it should work fine after that. There might even be a small arrow showing which way to switch it. The reason for the lock button is "just" for this, so you don't accidentally erase some wanted pictures or someone else.
Posted on Jan 06, 2008
  • 512 Answers
SOURCE: memory card locked
pull the SD card from the the slot and it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Posted on Jan 11, 2009
  • 149 Answers
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
Posted on Sep 09, 2009
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Posted on Dec 22, 2009
My SD card is locked and i cant get it unlocked
Nov 24, 2011 | Vivitar ViviCam 5024 Digital Camera
When i put insert lexor multi use into my fujifilm camera message 'protected card' with exclamation mark on screen. I am unable to take photos. Why?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 20, 2011 | Fuji FinePix S700 Digital Camera
I can see the pictures form my 1 gb sd card in my Casio Exilim. However, I cant see or transfer the pictures when I connect the camera to my laptop via the usb cable? the camera comes up as removalble...
It's good the laptop recognizes the camera as an external drive. A couple of things make sure you are looking at the SD card and not the cameras internal memory. Most point and shooters can't download directly from the internal memory to the computer they need to be transferred to the SD card first. Also if they are on the SD card for sure look to see if you have locked any of them cause that will prevent a download as well. It almost appears as if the SD card became locked which all it will alow you to do is look at teh picture and nothing else. I'm including a diagram of the little lock on the side of the SD card make sure that's in the open position.
Diagram
The position in thee little circle is where it need to be for unlock
Jan 06, 2011 | Casio Exilim EX-Z750 Digital Camera
Cant take picture says card is locked
There is usually a switch on the side of most picture cards (I am guessing its an SD card) this is the lock switch. Try setting it to the 'Unlocked' position.
Good Luck!
Jun 19, 2010 | Canon PowerShot A470 Digital Camera
My camera reads card locked. and i cant take a
The SD cards have a physical locking switch on the side. Pull the card out of the slot and take a look at the edge. The lock is a small micro switch on the edge.. It may have a label and arrow pointing to it..
Make sure it's in the off position.
Dec 07, 2009 | Canon Cameras
How do i unlock my sd card
There is a slider on the left hand side of an SD card which sets the card to Locked (lower position) or Unlocked (higher position - i.e. towards the top of the SD card). The first step is to check the position of this slider.
Note that the position of the slider does not affect the SD card in any way - it trips a switch inside the camera (or other SD reader). The slider MUST be in the upper position or the camera will say Card Locked - so if the slider has fallen off (they are very fragile!) the camera will assume it is in the Locked position.
Jul 19, 2009 | Praktica SlimPix Digital Camera
Casio Exilim EX-S880 how to unlock card
hello, check your card for a clip and see if its in lock position. set it to unlock.
also check if your card is compatible for you cam.
Mar 24, 2009 | Casio Exilim EX-S880 Digital Camera
Samsung digimax4010 memorycard locked cant take pictures
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 26, 2009 | Samsung Digimax 4010 Digital Camera
SD memory cards
Has another SD Card worked? is this the first you card you tried?
Be sure you have the correct type (size) SD card, there a couple of SD card types, micro (very small, etc.). It should go in only one way, does it fit and install easily? It should SNAP into placye.
A SD card is supposed to ONLY GO IN ONE WAY, the correct way.
It should SNAP in. Try to insert it in a different way very carfully.
DAVID
Jan 28, 2008 | Jazz DV-179 Digital Camera
Cameras Logo
67 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
