Question about Panasonic ES 8077S Electric Shaver
What does the red light mean on the panasonic shaver?
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
Jul 06, 2011 | Norelco Arcitec Electric Shaver -...
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
Mar 06, 2011 | Norelco Arcitec Electric Shaver -...
Red light came on for the first time since I have been using the razor
Red light means that the battery is very low. Charge the shaver and it will go out
Jan 05, 2011 | Remington R5130
What means red light on the right below corner
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is norelco RQ10 shaving replacement heads.
Jan 04, 2011 | Philips arcitec 1060 Electric Shaver
Red light came on in the form of the heads. Is it time to replace
This means that it is time to change the shaving heads. You will find Arcitec replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Jun 11, 2010 | Norelco Arcitec Electric Shaver -...
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Panasonic ES 8077S Electric Shaver Logo
96 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
