Question about Philips Televison & Video
How to adjust the color in the rear of the set
    Top Expert:
  • Philips Master
  • 14,553 Answers
Depending on what the set is doing wrong---nothing in rear to adjust unless you wish to make matters worse------
What is the issue---3 d looking or what.?
Posted on Dec 08, 2012
Red & green shadowing on the right side of picture
tried to adjust the convergence settings in the menu in the color adjustment in the tv menu. if can not adjust, you have bad either an open resistor or bad ic in the convergence circuit which control the color adjustment.
Aug 08, 2013 | Hitachi 60EX01B 60" Rear Projection...
Dont know how to adjust colors
tried first to look in the user manual if you have. if you don't have go to menu and then select color set up you can now adjust the primary color.
Oct 10, 2012 | Sony KP-51HW40 51" Rear Projection...
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color setting ......
you have t adjust it to the green to get it to set right, if it ont line up youll need to have it converged
Oct 27, 2008 | Akai PT5598HD 55" Rear Projection...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Colors not matched
Yes,there are convergence alignment adjustments, to be adjusted
by a technician after set is repaired.Replace STK392-560 IC's,then
check alignment..........T.
Oct 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Main factory color settings
You haven't supplied enough information to adequately address your problem. Color drives are not adjustable by the consumer and it would be risky for an inexperienced individual to attempt it. I may be able to provide more advice if you can supply a better description of your problem.
May 28, 2006 | Hitachi 60EX01B 60" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
